How to Setup DDNS with Freedns.afraid.org
Depends on the setup of the specific KillSwitch / DDNS setup(s) that you've used...
What happened after the Internet connection was restored in this case?
It ran for another day and then cut out again. Upon further investigation I think it is firmware related. I've upgraded to 386.7.1 and it appears more stable so far. Will leave it a few days to ensure it remains stable and then try and finally get this DDNS local access sorted!
Tried to use Afraid DDNS and it worked- DDNS active, just Let's Encrypt is not registering " Authentication failed on port 80, uses Asus.com instead" message.
Is there any easy way to make Let's Encrypt work with afraid.org free DDNS subdomain?
Actually, trying noIP now and it worked with Let's Encrypt right away.
