I really ask to help solve the problem with ASUS ROG Rapture GT-AC2900.
Good day to all members of the forum!
First of all, I ask for me for my English, I use a translator.
I also ask me to forgive me that I created a new topic, if it was not a right solution or place.
Since February 19, I use the best firmware from the respected RMerlin. And I am very happy about it!
But a few days ago I decided to try to change the DNS of my provider in my router, if this would affect anything and then returned everything back.
Since then, I can't use uTorrent, the port does not open so that I do not do ...
I dropped the settings of my router with all possible ways. I tried to make a refund to the factory firmware using the Rescue, but it did not help, returned back to 386.5_2.
Before changing the DNS, everything worked and the port was opened without any additional settings.
It was before, on my previous router, too, from Asus, but I replaced it to this and before my change DNS everything was in order.
I tried to open the port, which is specified in uTorrent, using a router, but nothing helps. The trackers writes a message that the port is closed and I can not join the distribution.
Maybe there is some kind of error in firmware in terms of DNS change?
I am ready to provide any information and make any actions only help me, please be the port and I could use torrents.
I am really looking forward to any help.
I ask for help.
Many thanks!
Run CMD as an admin>type ipconfig /flushdns>press enter>reboot your PC. Contact your ISP if it doesn't work.
I also do not change any settings in qbit, it just works.
Opening ports I made on the Crawling port tab in the Internet tab. I specified the QBittorrent service name The external port took the numbers that are specified in the program Internal IP address chose the protocol from the pop-up list indicated Both I opened the ports correctly or should I do something else?
View attachment 40452View attachment 40454
Have you tried it with prevent client auto doh set to auto? and privacy protocol none?
