:: ipBLOCKer :: Category blocking using iptables and ipsets
Have you tried as suggested in the Guide
Check the name of super user on your system. If it's other then root, please fix it at /opt/etc/crontab.
As an example, asuswrt(-merlin) uses admin:
sed -i 's/root/admin/g' /opt/etc/crontab
NOTE:
Since entware has the vixie's version and as
@ rhyzhov_al pointed out $USER needs to be part of the job description
i.e.,
0 * * * * $USER scriptcall
The elegant approach would be to as you say having cron.allow
That will fix the system-wide crontab as in /opt/etc/crontab. Thinking back..in fact we don't need per-user crontab in a "single user" environment. So if Entware cron is detected, a job can simply be scheduled by appending to /opt/etc/crontab. It'll be picked up by cron shortly after without bouncing any process.
In case someone insist on per-user cron, here is how-to:
echo admin > /opt/etc/cron.allow
ln -s /opt/etc/cron.allow /opt/var/cron/cron.allow
With the above one-time change, 'crontab -e' and its other command line options shall work in Entware.
Adding a $USER to cron.allow and the soft link are elegant.
@Odkrys  Try this approach.
Do a test after configuration with @kvic's suggested steps to see if crontab is working for $USER.
I have included a quick fix for you, uptake the file and in the .ipBLOCKer.config file add the below
CRON_USER=$USER
Do the above ONLY if vixie's cron needs $USER in the crontab schedule.
You would have to rename the extension of the file from .txt to .sh
