WANFailover Issue with WF and ax11000 pro?
JGodfrey82
@Ranger802004 is there a known issue with the ax11000 pro or USB 3 maybe? I cannot get WF script to configure, I completely factory reset, formatted my usb, reinstalled swap entware and then tried WF install and I'm still getting the same hang when trying option 5.
My alias also doesn't seem to work as running wan-failover at cli just gives not found.
The only error I ever see is when uninstalling I get
wan-failover - Uninstall: /jffs/scripts/wan-failover.sh deleted.
Command line is not complete. Try option "help"
Error: inet6 prefix is expected rather than "100".
awk: /jffs/configs/wan-failover.conf: No such file or directory
Any help appreciated as I've never had an issue with my ac68 or ax86 models.
Not that I'm aware of but open up a GitHub issue so I can look into it.
Thanks I opened a git issue, I also set my logging to debug and see the below error over and over again when it is installed:
DEBUG log error over and over again:
Sep 5 21:28:43 wan-failover: Debug - failed to set WAN1GWIFNAME
I responded to your issue.
