kamoj
Yes you are right in your assumptions!Hello! Thanks for getting back to me! I may try the DNScrypt not sure yet, but will think about it for sure.
Out of curiosity and frustration of trying to get my speed back through VPN, right away I flashed back to dd-wrt (by the way forums are back up, but GUI is super slow, many many others have been having problems since the big sur 11.3 and iOS 14.5 update). So slowly I put back my 2 VPN providers, I noticed on Voxel and your add on, I was getting 50mbps via wireguard, and with dd-wrt maxing out at 100mbps, I dont know how they do it, maybe faux newer linux kernal? like they are faking it some how.
So tonight in a couple of hours, I will flash back to Voxel and your addon, very curious to do the speed test and you are right, if I can hit 100mbps with OpenVPN why not just stick with that, until my ISP can provide a higher speed like 250mbps package then ill think about wireguard, good advice. Plus when I use Voxel and your add on I do feel at homeRouter just feels much smoother.
Just a thought, would the R9000 since it has a newer linux kernel I'm assuming, will provide faster wireguard speeds?? R9000 is actually overkill for my needs, live in a small condo and the R7800 is perfectly fine![]()
It's "all" about the kernel integration.
The R7800 runs a wireguard-go application all user space program.
I've read some R9000 user had 250 Mbps with Wireguard.
For R9000, it´s got 4 cpu cores, vs 2 for the R7800.
Wireguard is multi-threaded so it uses all cores, while OpenVPN is single-threaded.
So 120 Mbps for the R7800 single core without HW-support is incredible! Bravo @Voxel.
PS
If you want a cheap but still very good router, look at the Asus RT-AC86U.
It performs as well as the R9000 to a fraction (1/3) of the cost.
