Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW
Changes in kamoj-addon beta version 2023-11-23 5.5b37
- Supervision of WiFi changed to take care of a rare case where the radio just stalls/freeze (@LeKeiser)
This supervision can be disabled in:
Supervision: RESTART SUPERVISION (Supervise and Restart failed resources): WIFI (2.4 GHz and 5 GHz bands):
"Exclude detailed iwlist test"
- Supervision of DNS using nc/netcat can now be disabled in:
Supervision: RESTART SUPERVISION (Supervise and Restart failed resources): DNS:
"Exclude netcat test"
- AdGuard Home: New Adguard Home v0.107.41 default configuration, adapted to new AGH yaml file style.
- Settings: Added: Allow SSH access from wan (Internet). (@dj02) (@Voxel)
- Minor enhancements and editorial changes
- FAQ.txt updated with "Section 4: WiFi FAQ for R7800 and R9000" a.o.
Kamoj updated to latest version working perfectly 🤟 thank you so much for creating such an amazing addon.
And another huge thank you to Mr voxel for such an amazing firmware 🤟👍
And from myself thank you to everyone that has helped with beta testing.
Running in my simple environment r7800 ageis / dns / readycloud disabled router is working perfect
Hello all!
Today i installed the tools, even I've not tried to configure any I'm very excited, there are a lot possibilities here.
Just a quick question, i have already a pihole managing ads and dns , worth to add something more from addons?
Thank you
hi @kamoj , i would like to install kamoj addon to my router R9000 as wifi is not working, so want to enable wifi supervision. how do I get the addon. voxel curl returns 404
suggestion got from: https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=328025&sid=9e7c184b86e97d563219017c4095f72d
Q: My WiFi can not be switched on. It's on in ADVANCED: Advanced Setup: Wireless Settings,
but the BASIC page and the Kamoj add-on Router Information shows it as off.
Also there really is no WiFi available to connect. What can I do? (@Giudi001)
A: This is a Netgear bug that can also happen when you update the Firmware or at other times.
One reason is if you have switched off the WiFi with the hard button on the router,
and then made a Firmware update. The radios would then have been left unusable.
A1: The smart way: Install Kamoj add-on 5.4b24 or later, and enable WiFi Supervison in Settings.
Within one minute, the WiFi should be working again.
hi @kamoj, I have the exact same problem as @notsureifgoodname in that I have a R9000 router and I found this forum as a potential means of enabling the wifi on my router that is set to off no matter which firmware I use. I'd greatly appreciate your help in advising how I get the add on or an alternative method to enable the wifi supervision mode as the following telnet commands in the latest voxel firmware provide these errors:
root@R9000:/$ wlan up
sh: wifi: unknown operand
Sorry, rule does not exist.
uci: Entry not found
/sbin/wlan: /sbin/wlan: 1: execute_wifi_updateconf_event: not found
root@R9000:/$ wlan down
root@R9000:/$ wlan toggle
wifi1 no private ioctls.
/sbin/wlan: eval: 1: cannot create /sys/class/net/wifi1/led: Directory nonexistent
wifi0 no private ioctls.
/sbin/wlan: eval: 1: cannot create /sys/class/net/wifi0/led: Directory nonexistent
qcawifi: on led failed
Also, running the other command mentioned on gives:
root@R9000:/$ nvram default
killall: traffic_meter: no process killed
root@R9000:/$ nvram commit
root@R9000:/$ ngmtd="$(awk -F: '/"netgear"$/ {print $1}' /proc/mtd | grep mtd)"
root@R9000:/$ [ -n "$ngmtd" ] && flash_erase /dev/"$ngmtd" 0 0
Erasing 128 Kibyte @ 0 -- 0 % complete flash_erase: Skipping bad block at 00020000
flash_erase: Skipping bad block at 00040000
flash_erase: Skipping bad block at 00060000
flash_erase: Skipping bad block at 00080000
Erasing 128 Kibyte @ a0000 -- 0 % complete flash_erase: Skipping bad block at 000c0000
flash_erase: Skipping bad block at 000e0000
flash_erase: Skipping bad block at 00100000
flash_erase: Skipping bad block at 00120000
flash_erase: Skipping bad block at 00140000
flash_erase: Skipping bad block at 00160000
flash_erase: Skipping bad block at 00180000
flash_erase: Skipping bad block at 001a0000
flash_erase: Skipping bad block at 001c0000
flash_erase: Skipping bad block at 001e0000
flash_erase: Skipping bad block at 00200000
Erasing 128 Kibyte @ 220000 -- 3 % complete flash_erase: Skipping bad block at 00240000
flash_erase: Skipping bad block at 00260000
flash_erase: Skipping bad block at 00280000
flash_erase: Skipping bad block at 002a0000
flash_erase: Skipping bad block at 002c0000
flash_erase: Skipping bad block at 002e0000
flash_erase: Skipping bad block at 00300000
flash_erase: Skipping bad block at 00320000
flash_erase: Skipping bad block at 00340000
flash_erase: Skipping bad block at 00360000
flash_erase: Skipping bad block at 00380000
Erasing 128 Kibyte @ 3c0000 -- 5 % complete flash_erase: Skipping bad block at 003e0000
flash_erase: Skipping bad block at 00400000
flash_erase: Skipping bad block at 00420000
flash_erase: Skipping bad block at 00440000
flash_erase: Skipping bad block at 00460000
flash_erase: Skipping bad block at 00480000
flash_erase: Skipping bad block at 004a0000
flash_erase: Skipping bad block at 004c0000
flash_erase: Skipping bad block at 004e0000
flash_erase: Skipping bad block at 00500000
flash_erase: Skipping bad block at 00520000
flash_erase: Skipping bad block at 00540000
flash_erase: Skipping bad block at 00560000
flash_erase: Skipping bad block at 00580000
flash_erase: Skipping bad block at 005a0000
flash_erase: Skipping bad block at 005c0000
flash_erase: Skipping bad block at 005e0000
flash_erase: Skipping bad block at 00600000
flash_erase: Skipping bad block at 00620000
flash_erase: Skipping bad block at 00640000
flash_erase: Skipping bad block at 00660000
flash_erase: Skipping bad block at 00680000
flash_erase: Skipping bad block at 006a0000
flash_erase: Skipping bad block at 006c0000
flash_erase: Skipping bad block at 006e0000
flash_erase: Skipping bad block at 00700000
flash_erase: Skipping bad block at 00720000
flash_erase: Skipping bad block at 00740000
flash_erase: Skipping bad block at 00760000
flash_erase: Skipping bad block at 00780000
flash_erase: Skipping bad block at 007a0000
Erasing 128 Kibyte @ 7c0000 -- 11 % complete flash_erase: Skipping bad block at 007e0000
flash_erase: Skipping bad block at 00800000
flash_erase: Skipping bad block at 00820000
flash_erase: Skipping bad block at 00840000
flash_erase: Skipping bad block at 00860000
flash_erase: Skipping bad block at 00880000
Erasing 128 Kibyte @ 920000 -- 13 % complete flash_erase: Skipping bad block at 00940000
flash_erase: Skipping bad block at 00960000
flash_erase: Skipping bad block at 00980000
flash_erase: Skipping bad block at 009a0000
flash_erase: Skipping bad block at 009c0000
flash_erase: Skipping bad block at 009e0000
flash_erase: Skipping bad block at 00a00000
flash_erase: Skipping bad block at 00a20000
flash_erase: Skipping bad block at 00a40000
Erasing 128 Kibyte @ a60000 -- 15 % complete flash_erase: Skipping bad block at 00a80000
flash_erase: Skipping bad block at 00aa0000
flash_erase: Skipping bad block at 00ac0000
flash_erase: Skipping bad block at 00ae0000
flash_erase: Skipping bad block at 00b00000
Erasing 128 Kibyte @ b20000 -- 16 % complete flash_erase: Skipping bad block at 00b40000
flash_erase: Skipping bad block at 00b60000
flash_erase: Skipping bad block at 00b80000
Erasing 128 Kibyte @ ba0000 -- 16 % complete flash_erase: Skipping bad block at 00bc0000
flash_erase: Skipping bad block at 00be0000
flash_erase: Skipping bad block at 00c00000
flash_erase: Skipping bad block at 00c20000
flash_erase: Skipping bad block at 00c40000
flash_erase: Skipping bad block at 00c60000
Erasing 128 Kibyte @ c80000 -- 18 % complete flash_erase: Skipping bad block at 00ca0000
flash_erase: Skipping bad block at 00cc0000
flash_erase: Skipping bad block at 00ce0000
flash_erase: Skipping bad block at 00d00000
Erasing 128 Kibyte @ d20000 -- 19 % complete flash_erase: Skipping bad block at 00d40000
flash_erase: Skipping bad block at 00d60000
flash_erase: Skipping bad block at 00d80000
flash_erase: Skipping bad block at 00da0000
flash_erase: Skipping bad block at 00dc0000
flash_erase: Skipping bad block at 00de0000
flash_erase: Skipping bad block at 00e00000
flash_erase: Skipping bad block at 00e20000
flash_erase: Skipping bad block at 00e40000
flash_erase: Skipping bad block at 00e60000
flash_erase: Skipping bad block at 00e80000
flash_erase: Skipping bad block at 00ea0000
flash_erase: Skipping bad block at 00ec0000
flash_erase: Skipping bad block at 00ee0000
flash_erase: Skipping bad block at 00f00000
flash_erase: Skipping bad block at 00f20000
Erasing 128 Kibyte @ f40000 -- 22 % complete flash_erase: Skipping bad block at 00f60000
flash_erase: Skipping bad block at 00f80000
Erasing 128 Kibyte @ fc0000 -- 22 % complete flash_erase: Skipping bad block at 00fe0000
flash_erase: Skipping bad block at 01000000
flash_erase: Skipping bad block at 01020000
Erasing 128 Kibyte @ 1040000 -- 23 % complete flash_erase: Skipping bad block at 01060000
Erasing 128 Kibyte @ 11e0000 -- 26 % complete flash_erase: Skipping bad block at 01200000
Erasing 128 Kibyte @ 1ac0000 -- 39 % complete flash_erase: Skipping bad block at 01ae0000
Erasing 128 Kibyte @ 1be0000 -- 40 % complete flash_erase: Skipping bad block at 01c00000
Erasing 128 Kibyte @ 1ec0000 -- 44 % complete flash_erase: Skipping bad block at 01ee0000
Erasing 128 Kibyte @ 1f00000 -- 45 % complete flash_erase: Skipping bad block at 01f20000
Erasing 128 Kibyte @ 2000000 -- 46 % complete flash_erase: Skipping bad block at 02020000
flash_erase: Skipping bad block at 02040000
Erasing 128 Kibyte @ 22c0000 -- 50 % complete flash_erase: Skipping bad block at 022e0000
Erasing 128 Kibyte @ 23a0000 -- 52 % complete flash_erase: Skipping bad block at 023c0000
Erasing 128 Kibyte @ 2920000 -- 60 % complete flash_erase: Skipping bad block at 02940000
Erasing 128 Kibyte @ 2a20000 -- 61 % complete flash_erase: Skipping bad block at 02a40000
Erasing 128 Kibyte @ 2da0000 -- 66 % complete flash_erase: Skipping bad block at 02dc0000
Erasing 128 Kibyte @ 2e20000 -- 67 % complete flash_erase: Skipping bad block at 02e40000
Erasing 128 Kibyte @ 3540000 -- 77 % complete flash_erase: Skipping bad block at 03560000
flash_erase: Skipping bad block at 03580000
flash_erase: Skipping bad block at 035a0000
flash_erase: Skipping bad block at 035c0000
Erasing 128 Kibyte @ 35e0000 -- 78 % complete flash_erase: Skipping bad block at 03600000
Erasing 128 Kibyte @ 3620000 -- 79 % complete flash_erase: Skipping bad block at 03640000
flash_erase: Skipping bad block at 03660000
flash_erase: Skipping bad block at 03680000
flash_erase: Skipping bad block at 036a0000
flash_erase: Skipping bad block at 036c0000
flash_erase: Skipping bad block at 036e0000
flash_erase: Skipping bad block at 03700000
flash_erase: Skipping bad block at 03720000
flash_erase: Skipping bad block at 03740000
flash_erase: Skipping bad block at 03760000
flash_erase: Skipping bad block at 03780000
flash_erase: Skipping bad block at 037a0000
flash_erase: Skipping bad block at 037c0000
flash_erase: Skipping bad block at 037e0000
Erasing 128 Kibyte @ 3800000 -- 81 % complete flash_erase: Skipping bad block at 03820000
flash_erase: Skipping bad block at 03840000
Erasing 128 Kibyte @ 38c0000 -- 82 % complete flash_erase: Skipping bad block at 038e0000
flash_erase: Skipping bad block at 03900000
flash_erase: Skipping bad block at 03920000
flash_erase: Skipping bad block at 03940000
flash_erase: Skipping bad block at 03960000
flash_erase: Skipping bad block at 03980000
Erasing 128 Kibyte @ 39c0000 -- 84 % complete flash_erase: Skipping bad block at 039e0000
Erasing 128 Kibyte @ 3a00000 -- 84 % complete flash_erase: Skipping bad block at 03a20000
flash_erase: Skipping bad block at 03a40000
flash_erase: Skipping bad block at 03a60000
flash_erase: Skipping bad block at 03a80000
flash_erase: Skipping bad block at 03aa0000
Erasing 128 Kibyte @ 3ac0000 -- 85 % complete flash_erase: Skipping bad block at 03ae0000
flash_erase: Skipping bad block at 03b00000
Erasing 128 Kibyte @ 3b20000 -- 86 % complete flash_erase: Skipping bad block at 03b40000
flash_erase: Skipping bad block at 03b60000
flash_erase: Skipping bad block at 03b80000
flash_erase: Skipping bad block at 03ba0000
flash_erase: Skipping bad block at 03bc0000
flash_erase: Skipping bad block at 03be0000
flash_erase: Skipping bad block at 03c00000
flash_erase: Skipping bad block at 03c20000
flash_erase: Skipping bad block at 03c40000
flash_erase: Skipping bad block at 03c60000
flash_erase: Skipping bad block at 03c80000
flash_erase: Skipping bad block at 03ca0000
flash_erase: Skipping bad block at 03cc0000
Erasing 128 Kibyte @ 3ce0000 -- 88 % complete flash_erase: Skipping bad block at 03d00000
flash_erase: Skipping bad block at 03d20000
flash_erase: Skipping bad block at 03d40000
flash_erase: Skipping bad block at 03d60000
flash_erase: Skipping bad block at 03d80000
Erasing 128 Kibyte @ 3da0000 -- 89 % complete flash_erase: Skipping bad block at 03dc0000
Erasing 128 Kibyte @ 3de0000 -- 90 % complete flash_erase: Skipping bad block at 03e00000
flash_erase: Skipping bad block at 03e20000
flash_erase: Skipping bad block at 03e40000
flash_erase: Skipping bad block at 03e60000
flash_erase: Skipping bad block at 03e80000
Erasing 128 Kibyte @ 3ee0000 -- 91 % complete flash_erase: Skipping bad block at 03f00000
flash_erase: Skipping bad block at 03f20000
Erasing 128 Kibyte @ 3f60000 -- 92 % complete flash_erase: Skipping bad block at 03f80000
Erasing 128 Kibyte @ 3fc0000 -- 93 % complete flash_erase: Skipping bad block at 03fe0000
flash_erase: Skipping bad block at 04000000
flash_erase: Skipping bad block at 04020000
flash_erase: Skipping bad block at 04040000
flash_erase: Skipping bad block at 04060000
flash_erase: Skipping bad block at 04080000
flash_erase: Skipping bad block at 040a0000
flash_erase: Skipping bad block at 040c0000
flash_erase: Skipping bad block at 040e0000
flash_erase: Skipping bad block at 04100000
flash_erase: Skipping bad block at 04120000
flash_erase: Skipping bad block at 04140000
flash_erase: Skipping bad block at 04160000
flash_erase: Skipping bad block at 04180000
flash_erase: Skipping bad block at 041a0000
flash_erase: Skipping bad block at 041c0000
flash_erase: Skipping bad block at 041e0000
flash_erase: Skipping bad block at 04200000
Erasing 128 Kibyte @ 4220000 -- 96 % complete flash_erase: Skipping bad block at 04240000
Erasing 128 Kibyte @ 4260000 -- 96 % complete flash_erase: Skipping bad block at 04280000
flash_erase: Skipping bad block at 042a0000
flash_erase: Skipping bad block at 042c0000
Erasing 128 Kibyte @ 42e0000 -- 97 % complete flash_erase: Skipping bad block at 04300000
Erasing 128 Kibyte @ 4320000 -- 97 % complete flash_erase: Skipping bad block at 04340000
flash_erase: Skipping bad block at 04360000
Erasing 128 Kibyte @ 43a0000 -- 98 % complete flash_erase: Skipping bad block at 043c0000
flash_erase: Skipping bad block at 043e0000
flash_erase: Skipping bad block at 04400000
flash_erase: Skipping bad block at 04420000
flash_erase: Skipping bad block at 04440000
Erasing 128 Kibyte @ 4460000 -- 100 % complete
Neither set of telnet command has allowed me to turn the wifi on.
@kamoj Is vpn bypass and novpn the same ?On my R7800 my vpn is on and I have My chromecast in the vpn bypass.The no ip rule shows the ip of the chromecast.On the chromecast are apps bbci player 5 and itv x.I am in the uk so no need for vpn so hence the bypass.However the apps dont work they seem to detect the vpn. I also have a R7000 with the same vpn on and with The chromecast in the novpn the apps work perfectly. It seems the bypass on the R7800 does not completely bypass the vpn
Changes in kamoj-addon beta version 2023-12-12 5.5b38
- Supervision: Added Wireguard handshake supervision. (@jberry)
Handshake shall occur every 120 seconds. The addon uses 180 seconds as default timeout value.
The timeout value can be set through the router command prompt, e.g.:
nvram set kamoj_wireguard_handshake_timeout=150
nvram commit
- AdGuard Home: New Adguard Home v0.107.43 default configuration, adapted to new AGH yaml file style.
nvram commit
Thank you for your hard work!! Will update soon!
nvram commit
Thank you so much once again @kamoj & @Voxel
And merry Xmas to you both and hope you both have the most amazing new year🥳🍻👯‍♀️
And also to each and everyone else reading this also 🥰
nvram commit
kamoj-addon_231228-182747-5.5b39.md5 is missing.
Updated to b38, all running smooth again!
Thank you for making the tools that make my R7800 feel as if it is still brand new!
Hi guys, I'm having latency issue with kamoji add-on on the r7800, pings spiking to 2-3 seconds. Seems to be intermittant and only on the Lan side, as pings from ISP box seem unaffected. Only happens after kamoji addon installed, even without any VPN or adgaurd / DNS setup. It is intermittent but often enough to ruin any chance of online gaming.
Other than this issue the addon is epic, I can fanally have a VPN and torrent client on one low power device and manage the network properly.
I cannot install kamoj-addon_231212-145923-5.5b38_r9000.ipk. After downloading and try to install it, I got error below
root@USS-Vengeance:/$
root@USS-Vengeance:/$ /bin/opkg install --force-overwrite kamoj-addon_231212-145923-5.5b38_r9000.ipk
Collected errors:
* deb_extract: kamoj-addon_231212-145923-5.5b38_r9000.ipk: invalid magic
* pkg_init_from_file: Failed to extract control file from kamoj-addon_231212-145923-5.5b38_r9000.ipk.
Collected errors:
Read FAQ.txt and check MD5
