RoboSnipeKiller
Can i get a link to the latest build for my R7800 please?
Thank you for this awesome update!!!Changes in kamoj-addon beta version 2024-01-22 5.5b40
- AdGuard Home: Moved a bit later in startup sequence. (@jberry)
- Aegis: Improved installation of web-interface, and logging
- Router Information: nslookup timeout changed from 200 ms to 500 ms.
- Settings: Corrected bug showing code at top of window
- Stubby: Added: Wait for time synchronization before starting
- Wireguard Client: Changed hardcoded wg0 device to variable
- Wireguard Client: Better handling of missing wg program, more logs and search all disk for missing files.
(Wireguard sometimes crash and is deleted from disk. Wireguard Bug or backdoor?)
* Supervision: (Completely overhauled)
- Changed: "PING / TRACEROUTE SETTINGS" -> "Ping / Curl / Traceroute Settings for connection checks"
- Added: Normal Connection tests
Use Ping
Use Curl
Use Traceroute
- Added: VPN Connection tests
Use Ping
Use Curl
Use Traceroute
- Added: Restart on URL Connection failure
Restart VPN
Restart DNS
- Added: Extensive info for Supervision debugging
- Added: Max allowed time for each cURL test
- Added: Max alternative allowed time for each cURL test
- Added: Max allowed time for each short/fast communication tests in GUI
- Supervision: Bug fixed: "Only reboot if the dhcp gateway (default route) is reachable (recommended)"
- Supervision: Changed traceroute for supervision of VPN
- Supervision: Removed: Max time-to-live (max number of hops) for traceroute
- Supervision: Added: TTL time-to-live (number of hops) for traceroute
- Supervision: Adjusted text in DNS error log message. (@jberry)
- Supervision: ppp0: Improved detection of wan connection when using ppp0. (@jberry)
- Supervision: ppp0: Corrected detection of wan connection when using ppp0. (@jberry)
Added parameter to enable/disable new ppp0 wan connection.
To disable the new handling of ppp0:
nvram set kamoj_no_pppo_supervision=1
To enable the new handling of ppp0:
nvram unset kamoj_no_pppo_supervision
(Reboot is NOT needed!)
- Supervision: Changed traceroute for supervision of VPN. (@jberry)
- Minor enhancements and editorial changes
- FAQ.txt updated (@jberry)
Mr @kamoj a BIG thanx for all your hardwork, alwaysChanges in kamoj-addon beta version 2024-01-22 5.5b40
Use Ping
Use Curl
Use Traceroute
Use Ping
Use Curl
Use Traceroute
Restart VPN
Restart DNS
Installed: thanks for all these new features!Changes in kamoj-addon beta version 2024-01-22 5.5b40
Use Ping
Use Curl
Use Traceroute
Use Ping
Use Curl
Use Traceroute
Restart VPN
Restart DNS
This happens until adguard installation has finished.Hi Kamoj. Amazing that you are still working on the add-on for the r7800 but it's much appreciated. I've hesitated to touch anything for a while as it was all working fine but I've just updated Voxel to V1.0.2.104SF and your Add-on to V5.5b40. All good but I notice the link for Adguard Home in the Kamoj menu takes me to http://192.168.2.1/index.htm rather than the Adguard page. I think it needs to point at 192.168.2.1:8080.
VPN Bypass settings are stored in the normal R7800 configuration file, so no manual backup/restore should be done.Just one more thing I noticed. I followed the instructions for backing up the configuration in the Readme file before updating Voxel firmware. I then restored the configuration but it doesn't seem to have saved the VPN Bypass settings (the OpenVPN client settings are fine). Not a big deal but is it possible to back up this and if so, what would be the necessary command?
If you are only interested in changes, run:
Code:nss_status timestamp changes_only
while :;do cat /proc/sys/dev/nss/clock/current_freq; dmesg | awk '/Frequency Set to/ {print $NF/1000000" MHz"}' | tail -n1;sleep 3;done
Hi Kamoj. I re-installed and checked the log which showed "2024-02-10 15:23:49 585433.26 [ADGUARD] addon_adguard.sh 4099: INSTALL: Finished: AdGuard Home, version v0.107.44". I restarted AdGuard and refreshed the page but the link still takes me to the index page.This happens until adguard installation has finished.
Check AGH log file, then refresh page to get correct link.
Thank you for the report. Please add detailed log.Hi Kamoj. I re-installed and checked the log which showed "2024-02-10 15:23:49 585433.26 [ADGUARD] addon_adguard.sh 4099: INSTALL: Finished: AdGuard Home, version v0.107.44". I restarted AdGuard and refreshed the page but the link still takes me to the index page.
I am using Netgear R9000, b40 addon, and the latest AdGuard Home Version: v0.107.44, when I click on AdGuard Home, under Kamoj Menu, it shows my Router IP and port 8080 so it links to 192.168.9.9:8080 which is the AGH homepage. So everything is working fine for me.Any other user have this problem?
Here's the log of the installation process:Thank you for the report. Please add detailed log.
Also be sure to wait long enough before refreshing the Netgear router page.
Maybe Adguard has broken the compatibility - again.
There is a story of constantly changing the configuration file.
Adguard Home | port: 6060 port: 5300. DNS Servers: 5. Is installed but not running, but is on in nvram. |
Thread starter | Title | Forum | Replies | Date |
M | Kamoj Kamoj Addon 5.5 Beta for Netgear R7800/R8900/R9000 with Voxel FW - Continuation | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 28 |
Welcome To SNBForums
