Viktor Jaep
Part of the Furniture
Okeydokey then!
Okeydokey then!
Thanks... You can only block a single IP4 address, or a range of addresses (on the same subnet), or everything. I believe if you use CIDR notation, you would be able to extend a range beyond just a single subnet range... but I have personally never tried it with YazFi. Use at your own risk and test.hi so am i right in saying you can't block for multiple, single ip4 addresses? paranoid mode seems the most useful if im honest. one single ip doesn't do much and a range doesn't work on guest networks. I'm even finding it doesn't work on guest networks at all specifically has no effect on yazfi. Tbh yazfi seems to have a killswitch for any guest routed through vpn anyways. great script though!
Edit: how likely am i to run into issues where the killswitch fails for technical reason? I use a service that requires only one IP address otherwise I get banned. If it's likely it will shut down at an inopportune moment and IPs will change I think I might use YazFI for this as it shuts the internet down right away when vpn is tunneling. at least until you get the next release going with the 60 second checks![]()
@Viktor Jaep No need to lose sleep, but you are welcome to keep using that wonderful pioneering innovating spirit you gotThanks... You can only block a single IP4 address, or a range of addresses (on the same subnet), or everything. I believe if you use CIDR notation, you would be able to extend a range beyond just a single subnet range... but I have personally never tried it with YazFi. Use at your own risk and test.
So this script is probably going to just get phased out since the functionality built within Merlin's VPN interface will take over for it, since it takes care of most people's issues.
Like mentioned above, you might have better luck just using the killswitch functionality you find under the VPN section in the Merlin UI. I found that iptables rules can get overwritten when making simple updates to Skynet or other scripts that update the iptables... which then throws KILLMON out of whack, and would require KILLMON to refresh its rules on top of these changes.
I had planned to build something into KILLMON to frequently check for rule changes to make corrections if something goes south, but I'm probably going to just discontinue this project at this point.
If there's a huge outcry, I might reconsider... but seeing this is probably easily taken care of with built-in killswitch functionality, I'll won't lose any sleep over this.![]()
Not knowing what router model you're on, but being on the 386.14x track certainly means you don't have much time left there either. Sounds like it might be on the EOL list (https://www.asuswrt-merlin.net/about).Ahhh fair, sucks to see you move away from this but I guess everything has to die at some point! crappy thing is running the latest firmware for my equipment, 386.14, with the killswitch activated doesn't do a thing for me when the vpn disconnects. so in reality I might still have to use killmon sparingly.
Could also look to eventually upgrade equipment but not so sure I'd care to do it only for the killswitch.
Glad you're back on the KILLMON saddle! I know it's addicting pumping out new features for your own tech and I look forward to test driving it myselfSo after a few cups of coffee later -- thanks for the brainworms @jsn2233 and @SomeWhereOverTheRainBow, I think I'm going to reverse my stance... I've been looking for something to do after I'm done with my studies here hopefully pretty soon, so I will look at modernizing KILLMON with a bunch of new features. KILLMON was a fun project for me, and as it now seems to fall in my area of personal/professional interest, I feel a bit drawn to it. I believe it will help compliment and provide some alternatives compared to what is currently available in Merlin, and gives you a bit more control over what exactly you want to block.
This is what's on my to-do list... let me know if you or anyone else has any wishlist items when I get ready to revamp it.
Planned Enhancements
* Allow for multiple ranges/single IPs (user-defined)
* Use a short loop to determine if killswitch rules are in place, if not, re-apply rules to minimize exposure
* Update UI per the new standards
* AMTM Email integration/notifications when killswitch activates/deactivates? (optional)
Thanks for volunteering to test when it comes time!Glad you're back on the KILLMON saddle! I know it's addicting pumping out new features for your own tech and I look forward to test driving it myself![]()
Can you try excluding the wifi calling from the IP4 range? Like if that device is 192.168.50.10... then set the range to 192.168.50.11 - 192.168.50.150 (for example)? This won't solve the problem of it also needing to be included under killmon if the vpn goes down though.@Viktor Jaep - I'm using KILLMON along with DomainVPNRouting. I want some traffic to always go through the WAN; however, it seems that KILLMON stops that traffic on the devices I list in the IP4 range. Is there a way to have it check for authorized traffic based on DomainVPNRouting and only block anything not listed there?
As an example: I need Wifi calling to go through the WAN. It doesn't work well (sometimes at all) if it goes through a VPN. But, I also want my phone to be part of KILLMON and stop any other traffic if the VPN goes down.
No, because then I can't also have that device not access anything else on the WAN. I was hoping there might be some way to read the IPs from Domain VPN Routing to allow access to those while KILLMON stops everything else.Can you try excluding the wifi calling from the IP4 range? Like if that device is 192.168.50.10... then set the range to 192.168.50.11 - 192.168.50.150 (for example)? This won't solve the problem of it also needing to be included under killmon if the vpn goes down though.
Unfortunately I have no control over competing scripts that are modifying the same sets of iptables...![]()
Yeah... sorry about that. Instead of using KILLMON, perhaps you would have more luck with the built-in killswitch that you'd find in the Merlin VPN Client slot UI?No, because then I can't also have that device not access anything else on the WAN. I was hoping there might be some way to read the IPs from Domain VPN Routing to allow access to those while KILLMON stops everything else.
No worries. At least I finally figured out what the issue was. At first, I was wondering why some websites stopped working.Yeah... sorry about that. Instead of using KILLMON, perhaps you would have more luck with the built-in killswitch that you'd find in the Merlin VPN Client slot UI?
Welcome To SNBForums
