I've observed a similar issue on my AC66U. I got 2 wired computers and 1 wireless ones, smartphone. Whenever a wireless device makes a connection to the router, both my wired computers drop a single packet. I do not know why but it's easy to see with ifconfig on my 2 Linux computers. Also my smartphone (an LG Optimus L7 II) will disconnect after a certain time and reconnect back really fast. Sometimes it goes for many hours, usually 9-10, without dropping connection, but on other days it has difficulty staying connected for a few hours. I can't figure out if this is a router problem or a smartphone problem. However, I have a suspicion that it's the smartphone as I tried it on the TP-Link router and it behaves similary
I notice it on my r7000 because my video will buffer like crazy. then it will fix itself. And thats on a wired connection. 68u seems to suffer the same issue. and your 66u as well.
No. Dyn acquired TZO. different than DynDNS.Dyndns and TZO are the same now....DynDNS acquired them...and they are both PAID services.
You mean this which I linked earlier in this thread?
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=891186#891186
To be fair... tweaker and pro using a wireless router thats 250 isint pro. but thats a different discussion. And for home use its a bit overkill to go into anything better.
I'm not sure if this was already posted but I found this online.. http://www.tweaktown.com/reviews/62...-11ac-smart-wireless-router-review/index.html
Sent from my Nexus 5 using Tapatalk
That's pretty good considering the router just came out. With better drivers and tweaked firmware, this router should do a much better job.
Guys,
I have posted pics and a review when I picked up this beauty on Fri. on the Linksys forums.
Like many others , the build quality is top notch and the initial FW worked great out of the box. Once configured, router just worked!!!!!
Caveats:
1) Initial and latest FW work great....period
2) Thermostatic fan. fracking brilliant!!!!!
3) Build quality ..top notch
4) Wireless range is constant and steady
5) Worth the $50.00 differential against the competition
6) xbox1 ....no port forwarding needed. OPEN NAT !!!!!!
7) This router just rocks
THiggins, we all awaiting for your in depth review and tear down. Thus far were all giving end user experience. However, your technical writeup will say it all!!!!![]()
Read your review in other thread.
Two things that are nice to hear; setting get instantly saved and no more BS router resets between firmware updates. I'm so sick of it on Asus firmware. Even on DDWRT firmware, all settings are saved and applied with in seconds after making a hundred changes.
Waiting for Tim's review as well. I still feel people are getting a little too excited over this router. To me its Linksys finally catching up to the rest of the crowd and getting back in the game. The firmware seems a little slimmed down and lets see if Linksys actually develop it and continue supporting it. The Linksys forums are still full of threads with people complaining about firmware patches for other models that haven't seen updates in months. I hope Linksys prove me wrong as I wouldn't mind picking up one of these myself. I've become discouraged with all the bugs in Asus firmware.
Thanks...much appreciated. Like to add your able to save your router configuration. Found it under Troubleshooting>Diagnostic Tab. There your able to backup and restore router config and restore previous FW and Factory reset.
Last Fri when I had the router configured and internet ready, it saw that there was a new FW and I just downloaded and installed thru the GUI. Worked great no "reset" dance.
The latest router FW is located here. . It is in an image file and they say the router should be able to read it. For awhile I was thinking why would they do that and make us rip a disc just to see *bin* files.
The router has been up for 4 days and no problems to report!!!!!
Im ready for a change and get something else. The number 1 fix on Asus router, is to reset it. Dog ate your home work? Reset the router. Wife is cheating on you? Reset the router. Viagra no longer works? Reset the router!!
Or, Linksys waited and observed other companies by jumping on the AC band wagon way too soon. And now, these companies are spending months and months fixing bugs.
Everyone is waiting for firmware updates, not just Linksys users. Just look around.
I know for a fact that Asus and many DLink routers are near impossible to brick. They have a fallback firmware(usually called recovery mode or such) that are a god send when a flash goes wrong or firmware gets corrupted.
I really don't know much about how current Linksys firmware works and how easy/hard it is to brick their routers. I do know that their Belkin branded routers firmware is junk in of it self. I have had 4 of there routers(1 i owned personally) that were absolute trash and ended up on my pile of bricked/fubar Netgear routers that I use for target practice at the range
Asus certainly is at the top as far as pushing firmware updates go. I havn't seen any other companies do so good on that front.
"5) Worth the $50.00 differential against the competition"
This is very true. I struggled so much with my R7000 with QOS to work and (never) getting my media bridges to connect. Getting a refund for it then spending an extra $60 for the WRT1900AC was completely fine by me.
I'm very thankful I bought it.
Thread starter | Title | Forum | Replies | Date |
Linksys EA9500 - Local DNS | General Wi-Fi Discussion | 5 | |
P | Linksys Velop WHW03v1 firmware version 1.1.20.211186 | General Wi-Fi Discussion | 0 | |
M | WRT1900AC handshake issues? | General Wi-Fi Discussion | 5 |
Welcome To SNBForums
