Quick question - just moved into a new apartment and the cable is on the other side of the room from where I would like to have my PC set up. I am considering going wireless to eliminate the need to drill holes, go under the carpet, etc.
Question is this - I play a decent amount of games online and would like to keep latency as low as possible. Is this doable with wireless? If so, is there a particular type of AP/bridge combo that would minimize this? Its worth mentioning that I am in an area that is most likely blanketed with a large number of wireless networks.
Thanks!!!
Bryan
Thanks!!!
Bryan
