Memory leak in Asuswrt-Merlin
You will not be able to do reconnect 40 times a minute since the connection time seems to be around 5 seconds = 20 times - but I see no use for that currently. Why? Well my connection is not always that good, so I have frequent disconnect/connections from time to time - so in a way I do test that real world scenario :)
Will need fingers to trigger 40 times per minute I guess or need to run a script on the mobile client. lol. Was thinking that will accelerate the leak if it happens so..
As one gauge, for every "notify_rc" in syslog.log, it triggers the leak once in /sbin/preinit in 380.58 FW or a stock equivalent.
BTW, while keeping an eye for you guys, I spotted a new leak in /sbin/watchdog. More details here: http://www.snbforums.com/threads/sbin-watchdog-yet-another-memory-leak.32458/
@kvic can comfirm that leak
toast@Cerberus:/tmp/home/root# cat /proc/$(pidof watchdog)/status|grep VmRSS
VmRSS: 2432 kB
VmRSS: 2436 kB
avg ~15 min 4kb on RT-AC56U
Well I use Tasker for connecting over OpenVPN when WiFi drops out, so I guess it would be rather easy to adapt that to something more performance hungry?
ram uses on my 66u has been holding steady at 180mb free of 233mb I never seen it drop below that, then again have it set to reboot once a week.
Android? Haven't used it much...maybe manual toggle as a quick test if too much effort for automation.
On server side, can use 'management interface' CLI in OpenVPN to disconnect a client. Easy to automate with a shell script.
Another OpenVPN release, another memory leak fix included:
https://community.openvpn.net/openvpn/wiki/ChangesInOpenvpn23
Maybe they run out of bugs to fix :) Picked up one reported back in 2009..
Seems good to include on ChangeLog but little effect on actual use. To quote the guy's own words:
This function is only used by argv_printf_arglist(), and in a very specific
case, so it might be that this leak can not even occur. But coverity is
clearly right that this is a bug, so let's just fix it.
https://community.openvpn.net/openvpn/changeset/f8da74920998a8fa1125ec73c5e3397707b43017
