MerlinAU MerlinAU v1.4.2 - The Ultimate Firmware Auto-Updater (GNUTON SUPPORT!)
You definitely need to comment in the FW release thread(s), if only to see if there’s a lightbulb moment amongst other users.
Sure must, just redid the setup on the Samsung soundbar. Didn't change a thing, exact same setup and now connected. Odd thing it wasn't even showing up on the offline list of devices on the router. Washer shoud have failed, I half expected it to fail, but it connected right up. 🤷‍♂️
I'm sure there's a reason, I can't figure it out, there's no pattern to it, even downgrading to 388.8-4 doesn't fix it without a WPS reset, and then mostly (but not exclusively) on the nodes to use as a clue.
But now all done, everything connected and distributed to the Router and Nodes as they should be and were under 388.8-4 👍
So went ahead and updated my Signature ;)
A few of the devices that didn't connect (releatively new and can do WPA2/WPA3), I've had to go in and set them up, exactly the same as before and then they connected after I made the WPA2 change. The older one that should have a problem with that connected to the router but not to a node until I made the change to WPA2-Personal at the router for all the SSID's.
Just have one or two devices left, that even after a power cycle didn't conect that I anticipate will as soon as I reset them up, using the exact same settings as before 🤦‍♂️
Just to put a bowtie on this and wrap it up before going back to official business with MerlinAU addon.
Heres what I did to get myself a successful upgrade (FINALLY!)
1. Downgraded back to the stable versions of 3006.102.3 for the primary, and 3004.388.8_4 for the node.
2. Factory reset on both, then restored them to their working config from the morning of April 9th.
3. Confirmed all my devices reconnected as expected; gave the network a few minutes to breath after a reboot.
4. Prepared my network (knowing that WPA2/WPA3-personal was no longer going to work) I disabled it from any network that had it on.
In my case, that was my guest network, and my standard -5GHz network. For the guest; I set to WPA3-personal, and for the 5GHz standard, I set to WPA2 personal. Rebooted.
5. Reauthenticated any devices that went offline due to the above WPA changes. In my case that was only my work device by chance lol. Reauthenticated it to use WPA2 again instead of WP3 and all was good.
6. Did the firmware upgrades again on the node to release 3004.388.9 and 3006.102.4_beta1 on the primary.
7. Held my breath and whoohoooo! Time to have a beer:
Unlike you I did't have to change a setting on any device, just refresh the setup. But like you, I've a few beers ready to go. Just in time as the wife walks in.
Now, I'm tempted to play with fate tomorrow and change the SSID's at the router, to update the nodes, back to WPA2/WPA3-Personal to see what happens.
Maybe even shorten some of the device names to fix this (cleared and refreshed browser🤦‍♂️) ;
Update: jumped the proverbial gun, shorterning the longer names, which also fixed the already shorter names 🍺🍺👍
I just installed this not realizing that my router is not supported. How do I uninstall this script now? Even "MerlinAU.sh uninstall" refuses to run saying my router is not supported.
Did you try the interactive menu? Screenshots of what your talking about would go a long way.
Edit: nvm: i got it; will provide an update shortly.
Hi @mxxcon
I just added the fix for the uninstall in the same PR.
Run the following to be able to uninstall:
curl --retry 3 "https://raw.githubusercontent.com/ExtremeFiretop/MerlinAutoUpdate-Router/refs/heads/dev/MerlinAU.sh" -o "/jffs/scripts/MerlinAU.sh" && chmod 755 "/jffs/scripts/MerlinAU.sh"
MerlinAU 1.4.2 Released!
What's Changed/Fixed?:
PR: [ #451 ] - Minor Fixes and Additions
-After the Router PWD is set we now add a successfully tested or unvalidated result to main menu.
-Change the wording for the update process to fix nitpicks related to "anyways" vs "anyway" as reported by: @jksmurf here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-950762
-Update Minimum Versions to 3 behind production
  • Version"3004.386.13.2" for the 386 branch;
  • Version "3004.388.8.0" for the 388 branch
  • Version "3004.388.8.2" for the 3006.102 branch
-Fix the WebUI status for the changelog approval being "Disabled" instead of "TBD"
-Fixes some visual nitpicks of the WebUI
PR: [ #452 ] - Code Improvements
-Make sure the "FW_New_Update_Changelog_Approval" option is initialized properly under all circumstances.
-Show the Password "Verified" status in GREEN = GOOD.
-Minor cleanup.
(Thanks @Martinski4GitHub / @Martinski )
PR: [ #453 ] - Fix Changelog and Email Notifications and Patch Uninstall
-Fix a report from @nlurker for blank changelog URLs in the email notifications: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-951011
The Changelog check (pre-approval) was not running before the email notification with the run_now parameter.
-Quick fix to allow uninstall of the script when installed on unsupported routers as reported by @mxxcon here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-951128
PR: [ #454 ] - Improvement
-Miscellaneous code improvements.
PR: [ #455 ] - Fixes and Code Improvements
-Improved uninstallation workflow when users attempt to install MerlinAU on unsupported routers.
-Now the code will automatically prompt users to uninstall immediately after informing them that their current router model is unsupported. In such scenarios, this provides users a quick & easy way to uninstall.
As always, we highly recommend you update ASAP as this includes functional improvements and little bug fixes. Also as previously mentioned you must update to this version if you wish to have a smooth transition to the upcoming 1.4.0 release.
Thanks!
Get outta here .... I didn't get a mention for a real issue I picked up in the previous release but get an honourable mention for this bit of fun. You so funny :).
MerlinAU 1.4.1 Released!
PR: [ #449 ] - Patch Update Process
-Resolved some issues causing reports of having to run the update process twice, or reports of incorrectly identified updates.
Issues reported by @vlord here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-950588
And here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-950593
And @jksmurf here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-950590
And here: https://www.snbforums.com/threads/m...auto-updater-gnuton-support.91326/post-950749
As always, we highly recommend you update ASAP as this includes important functional improvements and bug fixes.
Thanks!
@jksmurf
You mean this above? ;)
-Minor cleanup.
View attachment 65018View attachment 65020
Thanks!
Awesome as always! Thanks for your dedication and good job.
Would be possible to receive an email notification whenever the script auto updates? 🥹
"Congratulations! The script successfully auto updated at X hours!"
"Oh no! An error occurred when trying to auto update. How is that possible? OMG, what a shame!"
