modmon modmon - WebUI for monitoring Virgin Hub 3 cable modem stats
Would graphing Virgin Media Superhub 3 stats from Merlin be useful for you?
  • Yes
    Votes: 13 86.7%
  • No
    Votes: 2 13.3%
  • Total voters
    15
  • Poll closed .
modmon: Older Merlin firmware detected - modmon requires 384.13_4/384.15 or later
modmon: Requirements for modmon not met, please see above for the reason(s)
Press enter to continue...
I am on 384.15
I am on 384.15
At least I'm consistent in the errors I make. Fixed, please try again.
Thank you very much, this has given me lot’s more to learn about [emoji4]
Looks so cool i wish there was support for the dreyteck vigor 130 also.
Oh I am liking this, I can't wait for a problem so I can shove a screenshot of this at them :p
Router was lagging so I uninstalled as a test, it didn't end well as the page is still there. (It did reinstall fine though)
Do you want to delete modmon stats? (y/n)
y
/opt/bin/modmon: line 834: can't open /jffs/addons/modmon.d/modmonstats_www.asp: no such file
modmon: Uninstall completed
GoNz0@RT-AC68U-D6A0:/tmp/home/root# modmon
-sh: modmon: not found
I have Xfinity and use my own Arris Surfboard SB6183 and I can access all the various tabs but this didn't work for me.
Unfortunately I wasn't able to get the stats, (hard & soft reboot) but looking in WinSCP after install I couldn't find the script in jffs (see 1) The add-on was visible but without any stats unfortunately. (see 2) with uninstall (see 3) I think it missed something with the installation somewhere. After uninstall the ad-on page with your script is still visible. After reboot your script is gone as well as the help page for add-ons All done on a fresh 384.15. Using a TG2492LG in the Netherlands.
/tmp/home/root# /usr/sbin/curl --retry 3 "https://raw.githubusercontent.com/jack
yaz/modmon/master/modmon.sh" -o "/jffs/scripts/modmon" && chmod 0755 /jffs/scripts/modmon && /jffs/s
cripts/modmon install
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 27823 100 27823 0 0 79494 0 --:--:-- --:--:-- --:--:-- 96273
modmon: Welcome to modmon v0.9.9, a script by JackYaz
modmon: Checking your router meets the requirements for modmon
modmon: Installing required packages from Entware
Downloading http://bin.entware.net/aarch64-k3.10/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
Installing sqlite3-cli (3300100-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/sqlite3-cli_3300100-1_aarch64-3.10.ipk
## _ ##
## _ __ ___ ___ __| | _ __ ___ ___ _ __ ##
## | _ ` _ \ / _ \ / _` || _ ` _ \ / _ \ | _ \ ##
## | | | | | || (_) || (_| || | | | | || (_) || | | | ##
## |_| |_| |_| \___/ \__,_||_| |_| |_| \___/ |_| |_| ##
## v0.9.9 on RT-AC2900 ##
## https://github.com/jackyaz/modmon ##
1. Check stats now
u. Check for updates
uf. Update modmon with latest version (force update)
e. Exit modmon
z. Uninstall modmon
modmon: New version of modmonstats_www.asp downloaded
modmon: Mounting modmon WebUI page as user1.asp
modmon: Something went wrong trying to retrieve Superhub stats
It’s been running for about 24 hours without any problems
I wish it would work with my SH 2ac :(
If you can find an SNMP output for the modem, I can look to integrate it
How about for netgear 500v modem? Thought I ask...
i found one but im not sure what exactly i need to set for it, these are the fields i found for it under SNMP Setup.
Get Community
Set Community
Manager Host IP
Trap Community
Notification Host IP
Trap Timeout
