Switch to single tar archive for shared-jy resources
rm -rf /www/user/shared-jy && rm -rf /jffs/addons/shared-jy
That is not a cable modem. This is a utility for cable modems.@Jack Yaz what data do you need to add particular modem support for zyxel vmg-8924-b10a please?
NEW: Change in minimum version requirement, see README!
NEW: Support for John's Fork of AsusWRT-Merlin
NEW: Option to toggle data output mode for weekly/monthly charts
NEW: Button to export/download CSVs used for charts
NEW: Add option to toggle time format in CSV exports between Unix and non-Unix time
CHANGE: Raw data output is now the default
CHANGE: Migrated from datasource plugin for ChartJS to D3js library
I notice the interface still refers to it as "Superhub 3 Stats" and "Superhub stats retrieved...".![]()
Ecstatic! My OCD can RIP now.
Depends, does the modem have a URL that returns the snmp/oids and values?Love the project. Question, wiill it work to pull my Sagemcom 3890v3?
Also, is it coming to AMTM?
Sent from my SM-G965F using Tapatalk
From what I know it does support SNMP but cannot find inside it's webgui anything to setup snmp agent or anything like that like with those technicolor.Depends, does the modem have a URL that returns the snmp/oids and values?
Can you send me a screenshot of what that looks like please? Can you also try access http://192.168.100.1/getRouterStatusFrom what I know it does support SNMP but cannot find inside it's webgui anything to setup snmp agent or anything like that like with those technicolor.
The only way to check data is using on of it's tabs manually after login in
http://192.168.100.1/sagemcom_network.php
We use essential cookies to make this site work, and optional cookies to enhance your experience.
