System Error Message
Part of the Furniture
unlike the ac68u the position of the heatsink and grill makes it harder to cool. There are laptop coolers that you can place below that move the air out from below the laptop and blows it out the side. i used to have such a cooler.
Or as someone mentioned you can just turn it upside down.
If it is possible, replacing the thermal pads/thermal paste and properly aligning them and placing the heatsink on properly may yield good results. make sure that this is done for the wifi chips too.
Heat causes unstable wifi so for the most stable wifi it is best to keep your wifi chips below 50C While the broadcom's CPU itself should be below 90 (60-70 is good). Having high temperatures can cause instabilities and also lead to your router dying early. Many manufacturers do not mind the high temperatures as long as they operate below the max safe in order to get you buying a new one every year.
