I posted some of this last night in the Skynet thread.
As of 2 days ago I had a 256MB USB stick in the router, which I figured was plenty since ABS uses under 20MB and Skynet didn't use anything (then), or much of anything, as with Pixelserv.
The Skynet decided it wanted a swap file, minimum size: 256MB. Swell.
I went and got (ie: stole from wifey) a 1GB thumbdrive.
In the router I formatted it for ext3, named it USBStick.
Things seemed to be going okay. I installed ABS, and then Skynet. Then I attempted to restore my backed up whitelist.txt and all hell broke loose. And by that I mean $#¡+ stopped working altogether. Things were suddenly no longer directories and files were not found all over the place. I don't know if this thumbdrive is dying or what.
Adamm was kind enough to recommend I use the excessively-named "MiniTool Partition Wizard Free 10.3" to format the thumbdrive and start over... which I accepted but needed to go to bed.
So here I am home from work and motivated to git-r-dun.
I install MTPWF10.3, umount the thumbdrive from the router and stick it in the computer so I can use MTPWF10.3 to delete partition / create partition / format partition as ext4. While this is going on I reboot the router so it can't possibly remember anything to do with the thumbdrive.
Router rebooted, ext4 "USBStick" stuck in the back, router recognizes it, I SSH in, check that /dev/sda1 is in fact /mnt/USBStick and all is well.
I run the AMTM script. Good. I run 1. Install AB-Solution
Listing compatible device(s) to install on.
Only ext2|ext3|ext4 formatted devices
are supported.
1. /tmp/mnt/USBStick
Select device: [1 e=Exit] 1
testing device /tmp/mnt/USBStick
device test passed, continuing...
checking /tmp/mnt/USBStick
for device label
device has a label, continuing...
installing AB-Solution on: /tmp/mnt/USBStick
Continue? [1=Yes e=Exit] 1
can't create directory '/tmp/mnt/USBStick/adblocking/scripts': Invalid argument
can't create directory '/tmp/mnt/USBStick/adblocking/.config': Invalid argument
can't create directory '/tmp/mnt/USBStick/adblocking/backup': Invalid argument
can't create directory '/tmp/mnt/USBStick/adblocking/stats': Invalid argument
can't create directory '/tmp/mnt/USBStick/adblocking/addon': Invalid argument
can't create directory '/tmp/mnt/USBStick/adblocking/custom_files': Invalid argument
WHAT. THE. HECK.IS.GOING.ON.HERE
How can I get these errors with a FRESHLY FORMATTED DRIVE, after ABS declares it to be satisfactory?!?!?
If I ls in /mnt/USBStick/ I see adblocking and lost+found, so it at least came up with SOMETHING before it stopped.
adblocking is drwxrwxrwx so it's not like there are no permissions.
Halp.
are supported.
for device label
Halp.
