Need help with Transmission in OpenWRT.
KGB7
I installed Transmission on GL.iNet Slate AX router and it its working well for most part, but im new to OpenWRT and I can't figure out why download speeds are slow.
I have tested same exact dozen torrents on my Intel based MacBook which saturates my wan speeds, but the download speeds via Transmission on the Slate router are all over the place. A lot of times it won't even use half the bandwidth. CPU usage on the router is around 2%.
Here is the config for the Transmission on the router. Please let me know if I need to change anything.
Cheers.
    "alt-speed-down": 50,
    "alt-speed-enabled": false,
    "alt-speed-time-begin": 540,
    "alt-speed-time-day": 127,
    "alt-speed-time-enabled": false,
    "alt-speed-time-end": 1020,
    "alt-speed-up": 50,
    "bind-address-ipv4": "0.0.0.0",
    "bind-address-ipv6": "::",
    "blocklist-enabled": false,
    "blocklist-url": "http://www.example.com/blocklist",
    "cache-size-mb": 2,
    "dht-enabled": true,
    "download-dir": "/tmp/mountd/disk1_part1/Movies/1Temp",
    "download-queue-enabled": true,
    "download-queue-size": 20,
    "encryption": 1,
    "idle-seeding-limit": 30,
    "idle-seeding-limit-enabled": false,
    "incomplete-dir": "//Downloads",
    "incomplete-dir-enabled": false,
    "invalid-key": false,
    "lazy-bitfield-enabled": true,
    "lpd-enabled": false,
    "message-level": 1,
    "peer-congestion-algorithm": "",
    "peer-id-ttl-hours": 6,
    "peer-limit-global": 1000,
    "peer-limit-per-torrent": 100,
    "peer-port": 62983,
    "peer-port-random-high": 65535,
    "peer-port-random-low": 49152,
    "peer-port-random-on-start": true,
    "peer-socket-tos": "default",
    "pex-enabled": true,
    "port-forwarding-enabled": true,
    "preallocation": 0,
    "prefetch-enabled": true,
    "queue-stalled-enabled": true,
    "queue-stalled-minutes": 30,
    "ratio-limit": 2,
    "ratio-limit-enabled": false,
    "rename-partial-files": true,
    "rpc-authentication-required": false,
    "rpc-bind-address": "0.0.0.0",
    "rpc-enabled": true,
    "rpc-host-whitelist": "",
    "rpc-host-whitelist-enabled": false,
    "rpc-password": "{a051a45912396255bb914dc6b01e75a8d4fbf92el4HSeDSC",
    "rpc-port": 9091,
    "rpc-url": "/transmission/",
    "rpc-username": "",
    "rpc-whitelist": "127.0.0.1,::1",
    "rpc-whitelist-enabled": false,
    "scrape-paused-torrents-enabled": true,
    "script-torrent-done-enabled": false,
    "script-torrent-done-filename": "",
    "seed-queue-enabled": false,
    "seed-queue-size": 10,
    "speed-limit-down": 100,
    "speed-limit-down-enabled": false,
    "speed-limit-up": 350,
    "speed-limit-up-enabled": true,
    "start-added-torrents": true,
    "trash-original-torrent-files": false,
    "umask": 18,
    "upload-slots-per-torrent": 10,
    "utp-enabled": true,
    "watch-dir-enabled": false
