What firmware version are you using?Had this router for a few weeks now, obviously not cheap but in terms of performance, rock solid and great wifi speeds
Using the latest 1.0.1.10 fw and it works a treat.What firmware version are you using?
Yes, the other features should come in time. At this point, the features that have the most chance of making a performance difference AX DL MU-MIMO and OFDMA are not enabled in the RAX200.What WiFi 6 features are they missing? I figured since the chipset is WiFi 6 certified, the other features will come in time. Do you think otherwise?
It depends on what those 20 people are doing, how far they are from the router and the radio in the devices.As for tri-band, you might be right about that not being the problem but I'm running out of ideas. I start getting people being unable to connect to my internet when I have my smart home IoT devices on and am throwing a party with around 20 people. Any thoughts?
@Axelrod360
Like you I also have a tonne of Wi-fi clients which is why I’m bought the tri band Netgear RAX200. I wasn’t too keen on the Asus AX11000 as ASU’s routers tend to be buggy as hell when first released.
I find the RAX200 to be a great router, with superb Wi-fi speeds & even better range/coverage than my old Linksys EA9500v2 ( also a great router). You won’t regret buying the RAX200
Why would you disable WMM?*Sigh* This thing is buggy. In Access Point mode , if you disable WMM, you can no longer connect to the WiFi at all! SSID is broadcast but you can no longer connect to it!
https://www.smallnetbuilder.com/wireless/wireless-features/30938-dont-mess-with-wmm
The latest RAX200 firmware (1.0.2.8) released a few days ago, now adds WPA3 & 802.11ax OFDMA amongst a few other things. I've also noticed wireless speeds have increased & become much more stable, probably d/t updated wifi drivers. For anyone upgrading to 1.0.2.8, I strongly recommend doing a hard factory reset after updating and then re-configuring all settings from scratch. Otherwise you might get regular internet disconnects like I was doing (a hard reset seems to have fixed this).
https://kb.netgear.com/000061780/RAX200-Firmware-Version-1-0-2-8
Its finally performing like a $600 router
Thread starter | Title | Forum | Replies | Date |
Netgear CAX30 | NETGEAR AX Routers and Adapters (Wi-Fi 6/6e) | 6 | ||
M | Netgear EAX20 BTRM messages | NETGEAR AX Routers and Adapters (Wi-Fi 6/6e) | 1 | |
M | Netgear Orbi RBK 852 | NETGEAR AX Routers and Adapters (Wi-Fi 6/6e) | 0 |
Welcome To SNBForums
