News NETGEAR Announces Tri-Band AX RAX200 Router
How did you do hard reset on these routers ?
It’s the pin hole method which is found at the rear of the router. Simply inset a paper clip and hold in for 20 seconds.
Set the router up as new without using a saved cfg.
I'm still trying to decide between the GT-AX11000 and the RAX200 (currently using the R7000). I need tri-band for the number of devices that get connected when I have parties and I figure AX is more future proof. Does anyone know what kind of processor the GT-AX11000 has? Is it the same one (company and model) as the RAX200?
I just bought the RAX200 (bought... not received, the shop claims it should come in a few weeks). Also moving from R7000.
I think the Asus GT-AX11000 has a BCM49408: Asus information
The RAX200 seems to be a BCM4908 also:
ASUS AX11000 BCM4908/ 2x BCM43684 / 2x BCM84880 1024 256 1+5 1148/2x 4804 4x2 4 3 + 3
Netgear RAX200 BCM4908/2x BCM43684/2x BCM84880 1024 512 1+5 1148/2x 4804 4x2 4 3 + 3
source compare
It seems the RAX200 has more flash... otherwise looks similar.
I guess the UI/FW will make the difference?
