Grassrootz
I do have an nvidia shield that is hard wired does that count?If you have any google home/chromecast they have been causing network issues galore. Wifi dieing, being spotty, sucking. Google confirmed.
My case I don't have any of those and still faced the issue.If you have any google home/chromecast they have been causing network issues galore. Wifi dieing, being spotty, sucking. Google confirmed.
I have a 88U with the same issue (5GHz Channel dropping)
I wound up sending it in for service as well after exhausting all known fixes
it was fine for the first 8mths or so
Om 380.xxxx branch issue is not present. service will return it to you saying hw is OK.I have a 88U with the same issue (5GHz Channel dropping)
Isn't or didn't Asus retire the 380.xx FW's due to security reasonsOm 380.xxxx branch issue is not present. service will return it to you saying hw is OK.
Install 380.69 from RMerlin or latest official 380.xxxx from asus site.
And suggest reporting the issue to asus through the feedback system incorporated inside firmware
Sent from my SM-G935FD using Tapatalk
Have you tried power cycling it? I've seen different behaviors from my 88u depending on the firmware version and have the reboot scheduler set to daily which seems to help it.I'm still on 380.69 merlin and today just had the 5GHz band drop after working fine for a few days. The router thinks devices are still connected when I go to the wireless log but no 5GHz users are connected. I'm perplexed about this on a brand new router what is the problem?
I had issues like this with my 3100. I was able to narrow it down to channel bandwidth. 80Mhz was causing issues so I had to lock it in to 40Mhz.I knew as soon as I said its working it wouldn't. So now my 5Ghz band is disappearing.
It was set to auto channel I went ahead and picked one at random and now its back but for how long?
Thanks I got it back (who knows how long) by changing the channel again but it was already manually set so I will keep this in mind if it happens again.I had issues like this with my 3100. I was able to narrow it down to channel bandwidth. 80Mhz was causing issues so I had to lock it in to 40Mhz.
Brand new AC88U here... Has anyone else noticed that on the AC88U anytime you fiddle with the wireless settings all WiFi goes out? I've been on the latest Asus firmware (Version 3.0.0.4.384.10007 2018/01/02) and on the latest Merlin (382.2 beta). I've experienced this problem with enabling the guest WiFi, changing the beacon interval, power strength, I mean literally any setting and the router loses WiFi the router thinks its still broadcasting them but none of the devices can connect. The only way to get it back is power cycling the router.
Another thing I noticed is when I tell the router to reboot using the gui it does its countdown but I have a constant ping going and I never see the router drop off during the "reboot".
Welcome To SNBForums
