New GPL
bluepoint
Looks like the corrected GPL is published today for RT-AC66U.
Version 3.0.0.4.374.726
Description GPL of ASUS RT-AC66U for firmware 3.0.0.4.374.726
File Size 424,94 (MBytes) 2013.09.23 update
They reuploaded the same corrupted archive unfortunately :(
They've been notified.
Asus has replaced their 3.0.0.4.374.726 archive. Publishing date is 2013.09.23.
File is corrupt. Again.
I think they are just mocking us. :mad:
Probably just a misunderstanding. The webmaster probably thought that the complain was that the zipfile on the server was corrupted, so they re-uploaded the same file again, and only made sure that the zipfile itself was ok.
Anyway as I've said, this is no biggy. There is nothing in that archive that is really that important over the N66 720 archive.
Asus has reuploaded a fixed version of the archive now, for those who want to tinker with it. Make sure your download is dated Sept 24th (today).
RMerlin has defeated ASUS, they surrendered and published the fixed archive. :)
LOL :)
On a serious note... any hope of Beta4 any time soon?
Seems like many people are having surprisingly too many issues Beta3... including yours truly.
LOL :)
The vast majority of complains have to do with wifi and the RT-N66U. There is nothing I can do about that, people will simply have to run the SDK5 build of it to solve their issues - this is the reason why this build exists.
I have been unable to reproduce the webui issues related to channels refusing to change for a few persons.
well, it more than that... mine is AC56 and I am seeing different issues:
- Stability - 33Beta3 does seem less stable than 33Beta1 - I caught myself power cycling the router regularly just to get this or that system connect. that was not limited to wireless clients - and I never had this issue before. and it is not a complete hang (like router is not responding), but certain blocks inside.... I am very very sorry - but I am currently so swamped that i was not able to capture the specific use case/log files
- Wireless connectivity - seen cases that I have to power cycle the router in order to get a previously working wifi connection to re-connect - and just like the issue above, it is not consistent
- USB 3.0 - plugging USB and enabling AI resulted in router real hang...
For what it's worth, I've had no problems with this version, and the wireless has been fine. I did the install, a factory reset, then manually re-entered all configuration info. I also remade all the connections on the wireless clients.
I am happy for you - but are you using the same router (RT-AC56U)?
How many clients are connected to your router - and what does the peak load looks like?
P GPL firmware 3.0.0.6.102_33340 for RT-AX88U Pro Released Asuswrt-Merlin 4
