Hi,I recently bought this router, it came with .260 firmware.
Built-in checker for new fw version says there is no new firmware.
Could it be a bug in .260?
Well, the summer time thing is a mess in the firmware. So far nobody is volunteering to clean up the mess...Thanks Joe!Could it also be that this firmware will add summer time option?
Because there is none in System settings section.
And yes, 5 GHz 40 MHz is still broken for me as well in this release.
+1. All Apple clients (MBP, iMac). The .271 works as inteded. Maybe next time.And yes, 5 GHz 40 MHz is still broken for me as well in this release.
Fwiw no 5G problems here with Samsung Galaxy Note 2 or Galaxy S3![]()
I'm using a galaxy S4 and connected at 150mbps on 5ghz connection
If .372 have the same drivers as of .354/370 then yes the 5GHz @40 is broken for intel client cards. All 5 GHz apple products(2 iphone 5, 1 mini ipad) in my household works though. What are you having problems with the apple clients you have?
Above that I noticed massive bandwith drops using the 5 GHz band (on my iMac the lowest bandwith is 14 mbit/sec. compared to 108 mbit/sec. with the .271 firmware, same RSSI).
I have (as many others) set the daylight saving on/off timing manually in the firmware and now it works for me.
With kind regards
Joe
PS.: As you are setting up the router, you should be aware of the need to clear NVRAM and start fresh with the setup after updating to the latest firmware...![]()
Are you talking about connection rate or bandwidth speed? If the latter, have you tried different channels?
Hi,Also I noticed merlins version the connected devices don't work after you hit refresh just keeps spinning 260 and 272 firmware did not do this. Any advice.
Thread starter | Title | Forum | Replies | Date |
B | DSL-N66U Probably a stupid question | ASUS N Routers & Adapters | 3 | |
E | asus rt-n66u replacement | ASUS N Routers & Adapters | 25 |
Welcome To SNBForums
