Small sticking point, the necessity to clone /www for custom page + images. Not sure how that will play with FreshJR for example
How is FreshJR making his mods to insert the new web GUI for the QOS?
a mount -o bind, which in theory should be fine, but there could be an interesting race in which mounts first out of ntpd and Fresh. Going to poke around at my router with a stickHow is FreshJR making his mods to insert the new web GUI for the QOS?
FreshJR binds a single page, ntpd requires binding the whole www directory from a cursory glance. Not sure if httpd can load images from outside /wwwI’d suggest making them share the same mount and making both edits in the same place should one already be installed.
I thought that too. but need to load in the generated graphs. If I can src them from outside www then great, but I suspect httpd is limited /www as the highest levelOh I see, maybe just have ntp bind a single page as well the same way.
Can't bind unless directory exists, so would need to bind on top of an existing subdir (and clone it)Bind a folder for them so it’s seen as a sub dir of www
/tmp/ var/wwwext ? I'll give it a go!Try using /wwwext (I think that's the name....working from memory)
With the emphasis for popular. I don't want to overcrowd amtm with tools that are only used by a handful users.
I am not sure how many use the NTP daemon.
On the RT-AC1900P (68U 384.9 FW), same as with the 86U:Can someone on non-HND send the outputs of the below please?
Code:which ntpd which ntpq
user@RT-AC1900P:/tmp/home/root# which ntpd
/usr/sbin/ntpd
user@RT-AC1900P:/tmp/home/root# which ntpq
Thanks - I think ntpq is installed via Entware's ntp-utilsOn the RT-AC1900P (68U 384.9 FW), same as with the 86U:
No ntpq.Code:user@RT-AC1900P:/tmp/home/root# which ntpd /usr/sbin/ntpd user@RT-AC1900P:/tmp/home/root# which ntpq user@RT-AC1900P:/tmp/home/root#
It's a headache for the user to need to clone the whole www directory for every f/w update thoughI have also FreshJR_QOS installed and it's giving no problem at all with following lines in post-mount:
Code:tar cf - /www | tar -C /opt/var -xvf - mount -a service restart_httpd
Welcome To SNBForums
