OpenVPN Client / Notification when loosing public IP
.I tested the scripts the last days. Something does not work.
Did you check Syslog for messages? :rolleyes::rolleyes:....that's what the script was designed to do i.e. log information so you can later examine the Syslog and identify if/when the loss of the Public VPN IP occurs if you don't receive the expected email(s).
grep ChkVPNIP /tmp/syslog.log
The script itself works and sends email when I manually start it with ./ChkVPNIP.sh 2.
But it seems that this does not start the ChkVPNIP.sh script..
cru a CheckVPNIP "15 * * * * /jffs/scripts/ChkVPNIP.sh"
What did I wrong?
Really? Can see/understand what is missing now??:rolleyes:
PEBCAK
Sorry, but no. Absolutely no clue, what you want me to see with your last post. If I do "grep ChkVPNIP /tmp/syslog.log" the result is:
ASUSWRT-Merlin RT-AC86U 382.1-2 Sat Dec 2 05:50:24 UTC 2017
emanuel@RT-AC86U:/tmp/home/root# grep ChkVPNIP /tmp/syslog.log
Feb 14 06:45:44 (ChkVPNIP.sh): 21064 v1.01b VPN Public WAN IP checker.....
Feb 14 06:45:51 (ChkVPNIP.sh): 21064 VPN Client 2 lost it's public WAN IP address
Feb 14 06:46:23 (ChkVPNIP.sh): 21255 v1.01b VPN Public WAN IP checker.....
Feb 14 06:46:30 (ChkVPNIP.sh): 21255 VPN Client 1 lost it's public WAN IP address
That's nice to know, but what should that help? I don't know why the public IP's get lost and I don't get an email if so. But that is the purpose of the scripts, or not?
But checking the log leads to other questions...Why it shows a completely wrong time and date. The router itself shows the correct time/date.
What happens if you run the script like this?
./ChkVPNIP.sh
If you mean this:
This is the timestamp indicating when RMerlin built the firmware.
Does the cron job appear when you issue:
cru l
Have you enabled
./ChkVPNIP.sh
Then I get the following (Just used ./ChkVPNIP.sh):
(ChkVPNIP.sh): 15644 v1.01b VPN Public WAN IP checker.....
(ChkVPNIP.sh): 15644 ***ERROR*** Missing arg1 vpn_id e.g. 1,2,3,4 or 5
Is it necessary to add the client to the script? But in the log both are noted...
cru l
Than this is showed:
emanuel@RT-AC86U:/jffs/scripts/init-start# cru 1
Cron Utility
add: cru a <unique id> <"min hour day month week command">
delete: cru d <unique id>
list: cru l
Yes.
Cron Utility
list: cru l
<sigh>
So clearly English is not your first language, but as you can see from the above 'cru' recognises one of 3 possible single alphabetic characters as the second parameter.
So the digit '1' is invalid but 'l' (short for 'list') is.
If I use cru l nothing happens.
So we are back to your post #20 and post #19 where somehow you did manage to type 'cru l' correctly.
Did you create script '/jffs/scripts/init-start' ?
What happens if you issue
cd /jffs/scripts
cat /jffs/scripts/init-start
./init-start
cru l
No. I did never use that code, because I don't now what for I should use it.
As written, I created the file cronjobs.sh in that directory. But you ask if I created the script '/jffs/scripts/init-start'. I thought, the scripts are cronjobs.sh and CheckVPNIP.sh.
If I issue the codes I get the following:
emanuel@RT-AC86U:/tmp/home/root# cd /jffs/scripts
emanuel@RT-AC86U:/jffs/scripts# cat /jffs/scripts/init-start
cat: read error: Is a directory
emanuel@RT-AC86U:/jffs/scripts# ./init-start
-sh: ./init-start: Permission denied
Sounds for me, like init-start should not be a directory?
Ha Ha ha ha o_Oo_Oo_Oo_Oo_O.......you don't think Sherlock?
P.S. Do you have any idea who created the '/nat-start' directory?
Clearly you deliberately lied or had a senior moment?
Why give you I Wiki link in post #16. Look up you init-start in the Wiki....hey let me do that for you...
What is init-start used for
One last time....have you created the script '/jffs/scripts/init-start? - like you said you did in post #20
Good luck troll
