OpenVPN Server: Can connect from iphone, not from Windows7
Good to hear it's sorted, but it doesn't explain why I was able to set mine up on my Windows laptop without the slightest problem and can switch between the servers on 1194 and 443. I'll possibly double check that really is the case and then maybe post my .ovpn file for you to compare.
Yes, that would be great to compare the two configs. the windows laptop i use is from my workplace, maybe the admin guys configured it in a specific way. I will test it on my fathers private windows 7 laptop end of next week...
I haven't been able to confirm that my laptop connects but I know for certain it has in the past on both servers (1194 and 443) and I don't believe anything's changed since.
Anyway, here 's my .ovpn file with my DDNS address and certs and keys "redacted" to use the word the talking heads are so fond of:
client
dev tun
proto udp
remote #######.asuscomm.com 1194
float
comp-lzo adaptive
keepalive 15 60
auth-user-pass
ns-cert-type server
<ca>
-----BEGIN CERTIFICATE-----
MIIDNDCCA###########
AnxUs6ZuNOo=
-----END CERTIFICATE-----
</ca>
<cert>
MIIDejC######09aiXtEKwCsr59hPPt
</cert>
<key>
-----BEGIN PRIVATE KEY-----
UtxG8Jll2Mk1vHE5#####%%%%%
-----END PRIVATE KEY-----
</key>
resolv-retry infinite
nobind
Perhaps it helps?
