... and it booted!!!!
So I measure the internet speed using 200Mb file download at testmy.net and this is highest ever on VPN: 22.5 Mbps
Turning VPN off, the same site: 24.5 Mbps
This is, ladies and gentlemen, reason I overclock![]()
How is the stability after memory speed bump?
How to overclock it?
saying that - if anyone know a program to stress test the router, i will gladly try it. Same with PC overclocking - sometime you set crazy clocks, and it will even boot to windows, but the moment you load CPU, it BSODs.
I am thinking to try to download something very fast like Ubuntu or another legit torrent to max out my download speed, but what will it prove it?
It won't prove much since VPN use one core only. You would have to disable HW acceleration and max out the router's WAN speed (240Mbit) downloading huge files all the time. But as you have 10x slower WAN it is not possible. I am on 200Mbps so won't stress it enough as well...... or perhaps I could run VPN excluding some devices, disable HW acceleration and max out WAN speed on excluded devices, while on the other max out VPN speeds![]()
primitivo, can you please oc-ing on your very fast internet as soon as you solve cooling issue (hint - Staples might have a USB fan and yes, it works fine from the router port)? I really want to know if getting faster internet will bring any further internet speed improvement...
the load on the router:
- a PC with torrents (legit)
- down-them-all downloading 1GB file
- network transfer of 30GB at 75MB/s
- 1080p stream from server to smart TV
- few wireless and wired clients
- CPU load varies between .64 and .71
- CPU temperature - stable at 62 degrees
So I finally figure out how to do that SSH thing... this is awful - only one CPU core is loaded, the second one is completely idle!!!!!
All my downloads finished... need to start new ones...
SSH per core would be more detailed and accurate.
Anyway, are you in Siberia or in some other cold country?
I have just checked with someone else from my country and his CPU also run at 80 degrees. How come yours and Merlin's differ so much from mine?
no I am definitely not in Siberia... LOL
The room temperature is 24-25 degrees, that probably helps...
Did you press "1" ?
GreatIn N66U in nvram we have:
Code:clkfreq=600,300,150
The first value are the Mhz of cpu core, but I don't know about 300 and 150 values.
Reduced speed value? Memory clock?
Now I'm trying 630,300,150...
Welcome To SNBForums
