Page sometimes loading hours....
I will look at this. Don`t want to screw a other modem. My wife already believe I do this specially to have always the newest and fasted :-)
Well yeah this modem has also kind of Routing that's why the Public IP is not coming to the router even when the ports are open. I have actual 2 of them which works with the same style. Plug them in and they are detected as a normal Ethernet Device. The One I have is the Huawei E353 and the second is ZTE MF823 (but this I screwed yesterday probably)
OK, I just realized that this is a setup with a USB-SurfStick and not with a "real" modem that comes with an ethernet port :rolleyes:
The fact that you don't see the problems inside a VPN connection indicates that this might as well have something to do with your 3G/4G service provider and the plan you purchased.
The 3G APN you're on will probably have a transparent proxy, which does not kick in when you're inside a VPN.
Maybe, also try to use the default DNS from your provider and not google's DNS and see if that improves things.
Partly agree. But don't believe that's the Problem with my Provider as I'm on a Business APN. Also its working fine when the same stick is in the Laptop. I will Upgrade today to the latest Beta, Use the new Huawei Modem I baught and than I will see whats going on and if its gets better.
I found the way to set the Stick to working serial modem so hope that the problem are solved with this... Will Update in some days on the issue :-)
I think I found the issue with the new Beta1 Firware:
Apr 14 20:30:12 kernel: DROP IN=eth3 OUT= MAC=58:2c:80:13:92:63:58:2c:80:13:92:08:08:00 SRC=213.158.199.1 DST=192.168.1.100 LEN=132 TOS=0x00 PREC=0x00 TTL=250 ID=39499 PROTO=UDP SPT=53 DPT=56904 LEN=112
Apr 14 20:30:14 kernel: DROP IN=eth3 OUT= MAC=58:2c:80:13:92:63:58:2c:80:13:92:08:08:00 SRC=213.158.199.5 DST=192.168.1.100 LEN=132 TOS=0x00 PREC=0x00 TTL=59 ID=62379 PROTO=UDP SPT=53 DPT=56904 LEN=112
Apr 14 20:30:16 kernel: DROP IN=eth3 OUT= MAC=58:2c:80:13:92:63:58:2c:80:13:92:08:08:00 SRC=213.158.199.5 DST=192.168.1.100 LEN=132 TOS=0x00 PREC=0x00 TTL=59 ID=62380 PROTO=UDP SPT=53 DPT=56904 LEN=112
Apr 14 20:30:18 kernel: DROP IN=eth3 OUT= MAC=58:2c:80:13:92:63:58:2c:80:13:92:08:08:00 SRC=213.158.199.5 DST=192.168.1.100 LEN=132 TOS=0x00 PREC=0x00 TTL=59 ID=62381 PROTO=UDP SPT=53 DPT=56904 LEN=112
From this what I remember: 213.158.199.5 -> DNS Server from my Internet provider (T-Mobile Poland)
WAN IP 192.168.1.100 (well this is what I get from the USB 3G Dongel)
SPT=53 - I guess this is DNS ?
Any Idea why this should be blocked or how I can remove this ? This let the pages load long like mi last post in this forum here :-(
May I allow this and when yes how ?
so .... Now is all working fine.... I reset the router and made all from the scratch. All the settings are the same as before, but the only I didn't change again is the "Tx power adjustment" which I believe caused the issue. I set it to max and I think the Router didn't like it very much. All other is the same and I happy that now its working as I would like too :-)
Thanks for all your help, Ideas and suggestions !
