PC/Router hacked PLEASE HELP
Had an almost identical story. The "culprit" was an unshielded microphone cable picking up a local radio station combined with voice-to-text recognition.
Damn. Kudos on figuring this one out.
Yes, it was pretty strange as the system would work fine for a while (when the radio station had music) but would "start typing" at other times. The difficulty was really that the speech recognition software was crap. If it had worked better, it may have been able to type proper words and sentences rather than pretty much random characters, in which case it could have been obvious if it typed "here is the KABC 10 o'clock news" or something. Lol
Back to the OP, although others are encouraging you to try to fix this yourself, based on the level of panic, your stated level of knowledge and the current hardware and software configuration, I would personally strongly suggest getting a friend to help clean all your devices or even paying a professional. You seem to believe whoever told you that you need all new hardware but have difficulty believing those you've asked for help here. You state that you have been infected by unremovable rootkits across all devices without any real evidence of what the infection is.
I've lost count of the number of similar "the earth is falling" first time posts that turned out to be something relatively benign or not even a virus at all.
how would it not solve the problem thats the most extreme method of removing malware?
Do you plan to restore any of your data from the old computer onto the new one? If your router is compromised, how will a new router avoid the same fate? How do you connect to the internet? Are you on a LAN? Do you have a VPN and robust firewall? You don't even know what problem you have - you only know what you see. Just because the Sun comes up when the rooster crows doesn't mean the rooster causes the sunrise. There's a process to get to the bottom of things.
I mean no disrespect and no one is trying to change your mind. I have a buddy that argues with his plumber and gets flipped off - my dad was like that. What I could never understand though... if your car overheats on a country road and the mechanic tells you that your fan belt broke, do you insist that you only need a new radiator?
Take my advice, if you think you've been hacked or whatever... ask how you would find out. You'll get better mileage.
Don't listen to me - you do you, just trying to be helpful.
no i dont have anything important on it, by following basic safety measures when online, im on a lan why does it matter? i stated i have a dream machine which has a firewall ill buy another router with a firewall i dont need to know what the problem is only to know that there is one, funny how you cant answer the question with a simple yes that will resolve the problem almost as if you dont want me to solve it.
funny how you cant answer the question with a simple yes that will resolve the problem...
You have already made up your mind this is what you're going to do. Your question was "how I could install these items without getting hacked again". To answer that question we need to know how you got hacked in the first place and which devices were affected. Without knowing that we can't answer your question.
It’s your money; up to you how you want to spend it. The folks here know what it takes to stay secured. Buying a new equipment — unless it’s outdated, not fit for purpose, broken — isn’t a fix in the medium term. Because, the fundamental problem remains unsolved, risking another event. This is what you need to try and minimise.
the fundamental problems are resolved because now i know basic cyber security safety. If an intruder has an access point buying a new router with a firewall and pc will 100% remove the access point from the intruder couldn't you agree thats the most effective way unless i clicked on something or re connected a device that has malware/spyware
@routerinfection
If you're not going to take our advice then why should we invest time in your issue?
You don't need to spend $$$$ to fix this.
1. Hard reset your router to remove any access from someone externally and shut off remote control / services upon setup
2. Format your Drive to remove any potential infections and reload Windows / Linux / any OS to make it functional again
Simple as that.
@routerinfection
Simple as that.
The problem is i dont know how to do that, all i can do on a pc is click a search engine and google stuff lol i tried learning how to do some of those things and im not smart enough thats why im picking this route. please just respond to this yes or no would this method i stated fix my problem yes or no?
I’m glad you solved the problem.
I’m sorry if and unless I have missed the details, we have no view of your network topology, devices, how the intruder got in in the first place; without these, there is no way we can be sure you fixed the issue. Even if you have, there is no certainty it won’t in the future.
The intent is minimise the risk. This is what we all do because I cannot guarantee my network will be safer in the future.
Buying a new router and a PC for every breach isn’t a solution for most of us here. Thx for reply.
ill take that as a yes, i was told to configure the new firewall somewhere else could i do it at home or would someone's elses network be better to configure it on?
Fix all your problems for under $300.
If you don't know how to do it then take to Best Buy and have someone do it for you for $100.
so if i take my pc and router to best buy and say these things below
this will remove a hacker from my network/wifi and pc 100%
