[Poll] AB-Solution usage
Are you using AB-Solution on your router?
  • Total voters
    97
Mine started out on Padavan firmware along time ago recently moved over to Merlin since there isnt support for AC56u (Broadcom) on Padavan
Interesting. How's GitLab, do they have download stats? Seems you can host it on your own server. Mmh, might look into this.
Edit: Bummer, also no stats on GitLab. I wonder why not. How does one find out if your coding time is worthwile without at least minimal statistics?
i do it mostly for myself if someone else befits then its only good news :) btw outta curiosity how many does your blocklist block ?
mine is around 90k to 100k hosts that gets blocked
I'm not a very good coder, but it's fun and if you get something to work the way you want it to then that is satisfaction at it's finest.
What keeps me going and adding more stuff are the Users. If I have no idea if anyone's using it then I might leave it at one point.
btw outta curiosity how many does your blocklist block?
Four lists to choose from, see ab-solution.info for the hosts files used.
25k to 220k ATM. But this will change as IPv6 will be supported in the next version.
Actually the amount of hosts won't be changed but the amount of the raw entries will double, for each host there will be two entries, one for IPv4 and one for IPv6.
That's correct, what I forgot to add is that there will be more file types to choose from.
