Presence-detection with N66U / AC68U for homeautomation
hi all,
Sorry for writing into such an old thread but just have a created and scheduled to be run on my AX88U a small and nice presence script to see who is at home and when leaves.... Maybe would be useful for someone... :)
Bash:
#!/bin/sh
# Track who is at home script
# Copyright by JOD 2022-Jun-07
# Instruction:
#    1) Set the mac addresses, user names, and the home dir to store the temp and report fils (e.g. mounted SDCard or USB drive)
#    2) Ssh your router as admin
#    3) copy the the script file to the router into the root dir, let's assume its name is "who_is_home.sh"
#    4) Execute the following list of commends to schedule it with cron:
#        $ chmod +x ./who_is_home.sh
#        $ mv ./who_is_home.sh /jffs/
#        $ cru a every5mincheckwhoishome "*/5 * * * * sh /jffs/who_is_home.sh"
#        $ cru l
#    5) Go to your home dir and wait for 5 min to see the temp and report files there
#    6) Enjoy :)
# Define global vars and consts
# Debug mode flag - put 1 instead of "" to enable echoing of some vars and debug the script
DEBUG_MODE=""
# Specify the list of macs (devices of users) that will be tracked, if put zeros, would be ignored
mac1=11:11:11:11:11:11    # Jade
mac2=22:22:22:22:22:22    # Peter
mac3=33:33:33:33:33:33    # Max
mac4=00:00:00:00:00:00
mac5=00:00:00:00:00:00
mac6=00:00:00:00:00:00
mac7=00:00:00:00:00:00
# Map the user names to the macs of their mobile devices
user1="Jade"
user2="Peter"
user3="Max"
user4=""
user5=""
user6=""
user7=""
# Few important directories and files where the script will be located and keep temp files
home_dir="/tmp/mnt/Sys/track_my_home/"                    # Set the working dir to the mounted SD Card volume
report_file=$home_dir"report.txt"                    # Set the report name
temp_file=$home_dir"state.log"                        # Set the name of of temp file to keep previous run data
# Define a few useful functions
# 1) Get the list of currently connected macs
getConnectedMacs() {
    local x
    local connected_mas
    for x in `wl -i "$1" assoclist | awk '{print $2}'`
    do
        connected_macs=$connected_macs";"$x;
    done;
    echo "$connected_macs"
# 2) Define a function to easier check the mac in the list of macs
stringContains() {
    [ -z "$1" ] || { [ -z "${2##*$1*}" ] && [ -n "$2" ];};
# 3) Make a record in the report
makeRecord() {
    # if in debug mode, tell me what's going on...
    if [ ! -z "$DEBUG_MODE" ]; then
        echo $c_run_date" "$c_run_time": ""$1"
    fi
    # Append the requested info to the report file
    echo $c_run_date" "$c_run_time": ""$1" >> "$report_file"
# 4) Record if the status of the device/mac changed since the last run
checkMacStatus() {
    if stringContains "$1" $c_connected_macs; then
        if ! stringContains "$1" $l_connected_macs; then
            # if conneted now but was not previous time - record the user is home
                  makeRecord "$1: $2 is at home"
        fi
    else
        if stringContains "$1" $l_connected_macs; then
            # if not found in connected but was there the previous time - record the user is away
            makeRecord "$1: $2 is away"
        fi
    fi
# 5) Get the saved data from previous run
getLastState() {
    # if the temp file exists, get the requested line from it, otherwise return empty string
    if [[ -f "$temp_file" ]]; then
        echo $(cat "$temp_file" | sed -n "$1"'p')
    else
        echo ""
    fi
# 6) Save the current data for the next run
saveCurrentState() {
    # if 2nd param specified, re-create the temp file with the data provided, otherwise append the lines
    if [ -z "$2" ]; then
        echo "$1" >> "$temp_file"
    else
        echo "$1" > "$temp_file"
    fi
# Start the script
# Get the previous run date and set of connected macs
l_run_date=$(getLastState 1)
l_run_time=$(getLastState 2)
l_connected_macs=$(getLastState 3)
    echo "Last run date: "$l_run_date
    echo "Last run macs: "$l_connected_macs
fi
# Set the current date/timr and the set of connected macs
c_run_date=$(date '+%Y-%m-%d')                        # Get the date in format YYYY-mm-dd
c_run_time=$(date '+%H:%M:%S')                        # Get the time in format "HH:MM:SS:
c_connected_macs=$(getConnectedMacs "eth6")$(getConnectedMacs "eth7")    # Look in 2.4GHz (eth6) and 5.0GHz (eth7) network for device AX88U
# Mark the new day start in the report
if [ ! "$l_run_date" == "$c_run_date" ]; then
    makeRecord "---------- "$c_run_date" ----------"
fi
# Check the device/mac status and record that, if changed
checkMacStatus $mac1 $user1
checkMacStatus $mac2 $user2
checkMacStatus $mac3 $user3
checkMacStatus $mac4 $user4
checkMacStatus $mac5 $user5
checkMacStatus $mac6 $user6
checkMacStatus $mac7 $user7
    echo "Curr run date: "$c_run_date
    echo "Curr run macs: "$c_connected_macs
fi
# Save the current set of macs and the run date for the next run
saveCurrentState $c_run_date 1                        # Re-create the file with the current date
saveCurrentState $c_run_time                        # Append the time as next line - can be used to track whether the script is running as expected :)
saveCurrentState $c_connected_macs                    # Append the current set of connected macs as the 3rd line
# ---- End of Script ----
I Dual WAN switching detection Asuswrt-Merlin 1
