Sometimes it is best to quit arguing and let the other person be wrong. This is one of those cases.it must be there, othercase authenticated status of reply from stubby will be lost in dnsmasq and will never reach lan clients.
because this file is the only valid path with upstream (isp) nameservers that stubby can use.
right, not a really great idea to have it configured, taking into account ntp issue was fixed in alpha2 and dnsmasq will always try to resolve all [*.]pool.ntp.org via 1.1.1.1 w/o dot/dnssec/etc with this record even if internet connection was not built or can't be built yet (think about pptp/l2tp or pppoe+dhcp, or other vpn-foo).
yes, it's bad idea causing dns loop.
yep, add that servers via web ui.
things were changed, seems dnsmasq's dnssec works a bit faster unlike stubby with its additional uncached dot checking requests for every incoming one. so, dnsmasq now is used for dnssec for all non-dot + dot cases.
automatic anchor download is a good feature, but not a big deal.
no, they are different.
strict validation is about deeper checking of unsigned replies, dnsmasq takes steps to be sure they are really not signed. dnssec vs dnssec_return_status is more about bad/changed replies at the time when they can't be checked at all (due no root keys accesible, blocked by firewall, routing or so) and therefore dnssec validation is not functional.
Sent from my SM-T380 using Tapatalk
