Howdy folks,
For those who might have missed it (as mentions were buried in other threads), I will be officially supporting the RT-AX88U. I started evaluating the device a few weeks ago. Despite a few challenges (like that router firmware being currently based on code slightly different from the code used by other models), the increased workload in maintaining the firmware code for that device in parallel to other devices is manageable (and will probably be only until the time Asus merges it back on the same code branch as other models).
I have published a first alpha build in the Test Builds folder:
https://asuswrt.lostrealm.ca/test-builds
This build received limited testing so far. It's based on Asus's 384_4730 GPL (the latest release for that model at this time), which is code-wise fairly close to 384_32799 (it's a few changes further ahead from it, on its parallel branch). My build is forked off my 384.8 development, meaning they will share the same changes (with sometimes a slight delay between branch resyncs, so the AX88U build might be a few changes behind).
So far everything that was working on the RT-AC86U will also be working. That also means the same limitations will apply (no IPTraffic support, no AiMesh support).
Keep in mind that:
Please limit discussions in this thread to the RT-AX88U itself. Any discussion about other models is best posted in the existing unofficial 384.8 alpha thread.
Keep in mind that:
- These are still early alpha builds (meaning they are unfinished, and potentially less stable than a beta)
- Although I might be answering questions, I won't be providing any real support for these test builds. Primary reason for making these early builds available is to gather feedback. More in-depth testing will be once we reach the beta stage.
- Since it's based off my 384.8 development code, it means that beside RT-AX88U-specific issues, there might be other issues introduced by the 384.8 development phase itself. Please take a look at the Changelog to get an idea what might potentially be unfinished/changed/problematic.
- Once again, this isn't even beta quality yet, it's alpha. Running this on a network with a family of 5 that might get screaming if their Netflix is broken one night might not be a good idea.
