PSA - Check TrendMicro Signature
My RT-AX88U on Merlin's 3004.388.7 is reporting Trend Micro: Signature version 2.400 Updated : 2022/07/27 03:14.
Very strange date... My router is a time traveling machine?
future proof , you will be super protected from things not invented yet !
Looks like your router is not setting the time on boot. What are you using for DNS servers?
The "Threat Activities" graph is pretty hilarious. It looks like a huge spike, but it's just zero to one.
Well, the % increase is infinitely greater. So, graph looks accurate.
I checked under Advanced Settings/WAN: "Default status : Get the DNS IP from your ISP automatically."
I checked under Advanced Settings/System Log, System Time is currently correct.
Only time when the router's system time isn't set correctly is when the router restarts due to power loss and time/date resets back to May 5th, and then it'll update the time as indicated in the log with "time disparity of .... minutes detected".
I just did a manual check and it got it right this time: "2.408 Updated : 2024/06/15 13:51"
I was out of date. I did an update manually. Then looked in my log and found:
Jun 15 18:26:08 rc_service: httpd 1913:notify_rc start_sig_check
Jun 15 18:26:08 custom_script: Running /jffs/scripts/service-event (args: start sig_check)
Jun 15 18:26:10 BWDPI: fun bitmap = 43f
Jun 15 18:26:10 custom_script: Running /jffs/scripts/service-event-end (args: start sig_check)
I looked inside both /jffs/scripts/service-event and /jffs/scripts/service-event-end and they have the contents of one of the add on scripts yet nothing to run the signature check or other things. What should be in the two service-event scripts?
Nothing. The signature check is done by the firmware, not by user scripts.
How often does the router check? Mine has not updated.
