[Rclone] Some problems with chroot debian
stebrick
If I mount a webdav via Rclone to the Debian's EXT_DIR (see the S99debian script below), everything just works fine and I have no problem seeing the contents inside the chroot. However, if I mount it to its subfolder, says, "debian_sharedfolder/abcwebdav", I cant see the contents so mounted inside chroot at all. I did change chmod 755 for the subfolder and I'm not sure what else is wrong :(
My rclone mounting command is:
rclone mount abcwebdav:/ /tmp/mnt/sda2/debian_sharedfolder/abcwebdav --cache-dir /tmp --umask 000 --allow-other --vfs-cache-mode writes --allow-non-empty --daemon
The 2nd problem is automount. I cant seem to find a script online that'd do a rclone automount in asuswrt scenario. How should it look like? I believe it's a simple one but I'm not very good in linux. If there's a full script template I'd be much appreciated.
#!/bin/sh
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin
# Folder with Debian Bullseye
CHROOT_DIR=/tmp/mnt/sda2/entware/debian
# Some folder outside of sandbox,
# will be mounted to /mnt folder in Debian
# Uncommented "EXT_DIR=" line if you need to
# mount a folder inside debian (remove #)
EXT_DIR=/tmp/mnt/sda2/debian_sharedfolder/
CHROOT_SERVICES_LIST=/opt/etc/chroot-services.list
if [ ! -e "$CHROOT_SERVICES_LIST" ]; then
    echo "Please, define Debian services to start in $CHROOT_SERVICES_LIST first!"
    echo "One service per line. Hint: this is a script names from Debian's /etc/init.d/"
    exit 1
fi
MountedDirCount="$(mount | grep $CHROOT_DIR | wc -l)"
start() {
    if [ $MountedDirCount -gt 0 ]; then
        echo "Chroot'ed services seems to be already started, exiting..."
        exit 1
    fi
    echo "Starting chroot'ed Debian services..."
    for dir in dev proc sys; do
        mount -o bind /$dir $CHROOT_DIR/$dir
    done
    [ -z "$EXT_DIR" ] || mount -o bind $EXT_DIR $CHROOT_DIR/mnt
    for item in $(cat $CHROOT_SERVICES_LIST); do
        chroot $CHROOT_DIR /etc/init.d/$item start
    done
stop() {
    if [ $MountedDirCount -eq 0 ]; then
        echo "Chroot'ed services seems to be already stopped, exiting..."
        exit 1
    fi
    echo "Stopping chroot'ed Debian services..."
        chroot $CHROOT_DIR /etc/init.d/$item stop
        sleep 2
    done
    umount /opt/debian/dev/pts
    mount | grep $CHROOT_DIR | awk '{print $3}' | xargs umount -l
restart() {
        echo "Chroot'ed services seems to be already stopped"
        start
    else
            sleep 2
        done
        echo "Restarting chroot'ed Debian services..."
        done
        done
    fi
enter() {
    mount -o bind /dev/ /opt/debian/dev/
    mount -o bind /dev/pts /opt/debian/dev/pts
    mount -o bind /proc/ /opt/debian/proc/
    mount -o bind /sys/ /opt/debian/sys/
    chroot /opt/debian /bin/bash
status() {
        echo "Chroot'ed services running..."
    else
        echo "Chroot'ed services not running!"
    fi
case "$1" in
start)
    start
stop)
    stop
restart)
    restart
enter)
    enter
status)
    status
    echo "Usage: (start|stop|restart|enter|status)"
    exit 1
esac
echo Done.
exit 0
EOF
