[Release 384/NG] Asuswrt-Merlin 384.5 is now available
It has something to do with the firmware I'm pretty sure. When I did my update, I did a factory restore, did the update, factory restore, and a minimal config. I've tried multiple things with no real luck. I've also noticed, if I'm connected to the router wireless and make a network change on the wireless, I get dropped, and it never comes back, so I have to hard reboot, or connect hardline. In general, its very bizarre behavior.
Have you tried Factory Initialize?
Sent from my Pixel 2 using Tapatalk
Down to 305 MB now after 7 days.
I've been looking at this and it seems (on my router) that the process that continues to grow (in resident memory size) while the others stay pretty constant, is the web server (httpd). Mine started out at 1700kB (after I restarted it) and it's now grown in a few days to 3972kB:
admin@RT-AC68U-77D8:/tmp/home/root# ps |grep httpd|grep -v grep
483 admin 5296 S httpds -s -i br0 -p 8443
484 admin 6572 S httpd -i br0
admin@RT-AC68U-77D8:/tmp/home/root# grep VmRSS /proc/484/status
VmRSS: 3972 kB
  • Like
Reactions: kfp
I upgraded an AC88U from 380.62 (23-Sept-2016) - performance had gotten pretty bad and the known admin login was no longer working. Suspected it had possibly been hacked... so i was sad i could not log in to see.
Anyway just passed 24 hours uptime with no problems on 2.4 or 5ghz so far. Only 3 ethernet clients on the AC88U. I did a factory reset before and after flashing this version. Seems to be no problems so far.
The router is not my own so if i start getting wifi problem complaints i will post about it
I'm thinking most problems are with IOT devices... do you have any currently running? Seems Lifx lights work....so far.
I bought a ROG GT-AC5300 and it seems nest works with it, but none of my other IOT devices including Lifx. Total bummer...
VmRSS: 3972 kB
All I know is my free memory is dropping by about 2.5 MB a day. It’s down to 295 MB now.
Nothing IOT, sorry. The closest to IOT is a roku.
All I know is my free memory is dropping by about 2.5 MB a day. It’s done to 295 MB now.
And my free memory is dropping exactly one percent every week .... and I do not know why ....
I know! Bcs. it's used!!! E.g. for caching purposes - as long as you do not reach >90% used, you are fine! :rolleyes:
Stop worrying about something that is not a problem - it works like it should! :oops:
I know! Bcs. it's used!!! E.g. for caching purposes - as long as you do not reach >90% used, you are fine! [emoji57]
Stop worrying about something that is not a problem - it works like it should! [emoji15]
The reported cached memory is not increasing though.
It’s only not a problem until the router locks up because there’s no free memory left. A few people (including me) have had that happen under 384.5. I’ve never had it happen with 384.4 or earlier.
It happened to me as well this weekend after being up for around 9 days with less than 30MB of free memory remaining. It's hard to pinpoint the exact time or memory free as I was unable to use the GUI or even SSH into it. I was able to surf slowly, but DNS requests were mostly not working when my clients are pointing to the router for name resolution as well.
As of right now it's been up for a little less than 2 days and here's the memory utilization for the web server so far:
admin@RT-AC86U-2A88:/tmp/home/root# ps |grep httpd|grep -v grep
789 admin 12560 S httpd -i br0
admin@RT-AC86U-2A88:/tmp/home/root# grep VmRSS /proc/789/status
VmRSS: 7804 kB
Those are the exact same symptoms I had. I though my ISP was having issues since it kind of worked, but I got horrendous packet loss and DNS mostly failing. I could use the GUI, but SSH didn't work at all because processes wouldn't fork do to lack of memory.
It took about 24 days for that to happen though. I wasn't watching the free memory before that, but I'm watching it now and it's slowly dropping. It's not dropping fast enough to explain how I was out of memory though. Something triggered the cached memory size to increase and the router ran out of free memory.
Reading through this thread it looks like there are some rumours of memory leaks and possibly other issues. Is 384_5 safe to upgrade to? I'm currently happy on 384_4.2 (from memory.)
The leaks seems to be highly dependent on the environment/configuration. I’ve personally not observed any leaks.
And what’s your definition for “safe”? 384.5 fixed a lot of security issues and updated a lot of components, IMHO you should update to be more “safe”.
Hello,
Can someone tell me where is the "config" files for the drive that mount at the start up..
For unknown reason I have
/dev/sdb5 14.3G 3.3G 10.3G 24% /tmp/mnt/AB-Solution
/dev/sda1 3.6T 2.9T 706.0G 81% /tmp/mnt/sdb1
devtmpfs 251.4M 4.0K 251.4M 0% /tmp/mnt/AB-Solution/ent ware/debian/dev
/dev/sda1 3.6T 2.9T 706.0G 81% /tmp/mnt/AB-Solution/ent
I need to remove the Bold one.
Hello,
You can't remove the drive path as any drive connected to your router will be mounted somewhere.
Just either format the drive mounted on /dev/sda1 (4TB one) or remove the AB-Solution folder from it.
Hello,
there is no AB-Solution Folder on this drive .
If i do Fdisk -l
Filesystem Size Used Available Use% Mounted on
/dev/root 36.8M 36.8M 0 100% /
devtmpfs 251.4M 4.0K 251.4M 0% /dev
tmpfs 251.6M 4.3M 247.2M 2% /tmp
/dev/mtdblock4 64.0M 15.6M 48.4M 24% /jffs
/dev/mtdblock4 64.0M 15.6M 48.4M 24% /usr/sbin/tc
/dev/sdb5 14.3G 3.3G 10.2G 25% /tmp/mnt/AB-Solution
/dev/sda1 3.6T 3.0T 700.5G 81% /tmp/mnt/sdb1
devtmpfs 251.4M 4.0K 251.4M 0% /tmp/mnt/AB-Solution/entware/debian/dev
/dev/sda1 3.6T 3.0T 700.5G 81% /tmp/mnt/AB-Solution/entware/debian/mnt
This is causing me trouble with AB-Soluton
Hello,
If i do Fdisk -l
The folder might be hidden.
Can't you format that drive?
Why will i format my second drive? its probably mounting somewhere .. i can do a umount, so for sure its moungting somewhere this is what i need to find
Off course it's mounted on /dev/sda1 but the AB-SOLUTION folders on it is questionable.
Remove the drive, reboot the router and run fdisk -l again to check if you still see that path.
Also check the services-start and services-stop scripts in /jffs/scripts folder for any rouge entries.
