Experienced some weirdness here on my 87u
Logged on router and noticed no new entries in syslog after around 06, Seemed to have been some issues with isp connection around 05
But wan was restored (May 20 06:09:28 WAN_Connection: WAN was restored) ntpd,vpn server,vpn client,DDNS restarted and looked correct, After that no syslog entries
Rebooted router only part from shutdown was in syslog nothing more, SSH and enabled debug mode in skynet and restarted it(skynet), Still nothing i syslog
Turned off router for about 15min and removed power cord and pushed power button a few times, And started it again
still no new entries in syslog still only part from shutdown when i did first reboot
Did a backup on JFFS
After that i tested in /Administration/System/Enable local NTP server=no and apply(Before it was set Enable local NTP server=yes and Intercept NTP client requests=yes) (Dont know why i came to think of trying that something about reading of changes to ntpd when i upgraded to 384.11_2)
After that i got entries in syslog again..
Edit: Rebooted again and there is still a issue with my syslog, Again only see part from shutdown and then nothing, even when all is up and working(vpn server and client)
Edit2: Again set Enable local NTP server=yes and Intercept NTP client requests=yes and apply
Syslog works..Maybe a full reset incoming
May 20 14:42:45 syslogd started: BusyBox v1.25.1
May 20 14:42:45 kernel: klogd started: BusyBox v1.25.1 (2019-05-17 23:32:19 EDT)
May 20 14:42:46 dropbear[4465]: Running in background
May 20 14:42:46 custom_script: Running /jffs/scripts/service-event (args: restart leds)
May 20 14:42:46 hour_monitor: daemon is starting
May 20 14:42:46 hour_monitor: daemon terminates
May 20 14:42:46 custom_script: Running /jffs/scripts/service-event (args: restart usb_idle)
May 20 14:42:46 custom_script: Running /jffs/scripts/service-event (args: restart firewall)
May 20 14:42:46 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
May 20 14:42:47 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
May 20 14:42:47 custom_script: Running /jffs/scripts/service-event (args: restart bhblock)
May 20 14:42:47 custom_script: Running /jffs/scripts/service-event (args: restart dnsmasq)
May 20 14:42:47 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
May 20 14:42:47 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
May 20 14:42:47 Skynet: [%] Startup Initiated... ( skynetloc=/tmp/mnt/Zastoff/skynet )
May 20 14:42:48 Diversion: restarted Dnsmasq to apply settings, from /jffs/scripts/dnsmasq.postconf
May 20 14:43:11 Skynet: [#] 122364 IPs (+0) -- 1499 Ranges Banned (+0) || 0 Inbound -- 0 Outbound Connections Blocked! [start] [24s]
Edit3:
Downgraded to 384.11_1 (guess it`s very much like 384.11_2 wanted to reinstall so i see it really happen
) and did a Format JFFS partition,
That Solved it (Will try 384.11_2 again later)
