Removing (1) Appended to Share Name
mtrains
My AC68R (running 374.39 firmware) ran into some kind of error and it restarted the Samba server. After that one of my partitions has the (1) appended to its name. I am assuming it still thinks the partition with the original name is still mounted. There was a discussion about this a while ago and I couldn't find it through the forum search.
How do I get rid of the (1)? Power cycling the router didn't work. Ejecting the USB drive, unplugging and plugging it back in didn't help. I don't want to go through the hassle of a factory reset.
[Edit] Fixed it. SSHed into the router and found the directory with the original share name under /tmp/mnt. Removed it and rebooted the router and everything is fine now.
