RT-AC66U and K3770-Z USB dongle issue
rhomfj
Hi, I am not sure if this is the right place to post this and I apologize if it isn't.
I am using:
ASUS RT-AC66U - Firmware Version:3.0.0.4.354.29 (Merlin build)
Vodafone branded Huawei K3770-Z USB 3G dongle
The router seems to connect, get itself an ip address and the correct dns servers which is great.
It then falls into some sort of loop until it seems the whole USB port is closed down.
I have not been able to establish a connection to the internet over the router.
Is anyone able to help/suggest a way I can work out more about whats going on?
Here is a dump of the system general log:
Jan 1 00:00:12 dnsmasq[495]: started, version 2.65 cachesize 1500
Jan 1 00:00:12 dnsmasq[495]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Jan 1 00:00:12 dnsmasq[495]: asynchronous logging enabled, queue limit is 5 messages
Jan 1 00:00:12 dnsmasq-dhcp[495]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 1 00:00:12 dnsmasq[495]: read /etc/hosts - 5 addresses
Jan 1 00:00:12 WAN Connection: Ethernet link down.
Jan 1 00:00:13 kernel: sr0: scsi3-mmc drive: 0x/0x caddy
Jan 1 00:00:13 kernel: Uniform CD-ROM driver Revision: 3.20
Jan 1 00:00:13 RT-AC66U: start httpd
Jan 1 00:00:13 crond[518]: crond: crond (busybox 1.20.2) started, log level 8
Jan 1 00:00:13 kernel: usb 1-1.2: USB disconnect, address 3
Jan 1 00:00:13 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Jan 1 00:00:14 kernel: scsi 0:0:0:0: rejecting I/O to dead device
Jan 1 00:00:16 kernel: Uniform CD-ROM driver unloaded
Jan 1 00:00:21 dnsmasq-dhcp[495]: DHCPREQUEST(br0) 192.168.1.125 00:50:b6:5a:06:07
Jan 1 00:00:21 dnsmasq-dhcp[495]: DHCPACK(br0) 192.168.1.125 00:50:b6:5a:06:07 PC939
Jan 1 00:00:21 Samba Server: daemon is started
Jan 1 00:00:22 disk monitor: be idle
Jan 1 00:00:22 dnsmasq[495]: read /etc/hosts - 5 addresses
Jan 1 00:00:22 dnsmasq[495]: using nameserver 183.81.133.151#53
Jan 1 00:00:22 dnsmasq[495]: using nameserver 183.81.133.150#53
Jan 1 00:00:22 nmbd[574]: [2011/01/01 00:00:22, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan 1 00:00:22 nmbd[574]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
Jan 1 00:00:23 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 4
Jan 1 00:00:23 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Jan 1 00:00:23 kernel: usb0: register 'cdc_ether' at usb-0000:00:04.1-1.2, CDC Ethernet Device, 02:fd:d9:c9:af:96
Jan 1 00:00:23 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Jan 1 00:00:24 kernel: cdc_acm 1-1.2:1.1: ttyACM0: USB ACM device
Jan 1 00:00:24 kernel: cdc_acm 1-1.2:1.3: ttyACM1: USB ACM device
Jan 1 00:00:24 kernel: usbcore: registered new interface driver cdc_acm
Jan 1 00:00:24 kernel: drivers/usb/class/cdc-acm.c: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
Jan 1 00:00:25 kernel: scsi 1:0:0:0: CD-ROM Vodafone USB SCSI CD-ROM 0001 PQ: 0 ANSI: 0
Jan 1 00:00:25 kernel: scsi 1:0:0:0: Attached scsi generic sg0 type 5
Jan 1 00:00:26 pppd[647]: pppd 2.4.5 started by admin, uid 0
Jan 1 00:00:31 nmbd[574]: [2011/01/01 00:00:31, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan 1 00:00:31 nmbd[574]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.1
Jan 1 00:00:32 pppd[647]: Serial connection established.
Jan 1 00:00:32 pppd[647]: Using interface ppp0
Jan 1 00:00:32 pppd[647]: Connect: ppp0 <--> /dev/ttyACM0
Jan 1 00:00:36 pppd[647]: local IP address 27.123.190.149
Jan 1 00:00:36 pppd[647]: remote IP address 10.0.0.1
Jan 1 00:00:36 pppd[647]: primary DNS address 183.81.133.150
Jan 1 00:00:36 pppd[647]: secondary DNS address 183.81.133.151
Jan 1 00:00:36 dnsmasq[495]: read /etc/hosts - 5 addresses
Jan 1 00:00:36 dnsmasq[495]: using nameserver 183.81.133.151#53
Jan 1 00:00:36 dnsmasq[495]: using nameserver 183.81.133.150#53
Jan 1 00:00:39 rc_service: wanduck 496:notify_rc restart_wan_if 0
Jan 1 00:00:39 stop_wan(): perform DHCP release
Jan 1 00:00:39 kernel: br0: port 1(vlan1) entering disabled state
Jan 1 00:00:39 kernel: vlan1: dev_set_promiscuity(master, 1)
Jan 1 00:00:39 kernel: br0: port 1(vlan1) entering listening state
Jan 1 00:00:39 kernel: br0: port 1(vlan1) entering learning state
Jan 1 00:00:39 kernel: br0: topology change detected, propagating
Jan 1 00:00:39 kernel: br0: port 1(vlan1) entering forwarding state
Jan 1 00:00:41 dnsmasq[495]: read /etc/hosts - 5 addresses
Jan 1 00:00:41 dnsmasq[495]: using nameserver 183.81.133.151#53
Jan 1 00:00:41 dnsmasq[495]: using nameserver 183.81.133.150#53
Jan 1 00:00:43 rc_service: wanduck 496:notify_rc restart_wan_line 1
Jan 1 00:00:43 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0__dev_ttyACM0)!
Jan 1 00:00:43 dnsmasq[495]: read /etc/hosts - 5 addresses
Jan 1 00:00:43 dnsmasq[495]: using nameserver 183.81.133.151#53
Jan 1 00:00:43 dnsmasq[495]: using nameserver 183.81.133.150#53
Jan 1 00:00:43 dnsmasq[495]: exiting on receipt of SIGTERM
Jan 1 00:00:43 dnsmasq[714]: started, version 2.65 cachesize 1500
Jan 1 00:00:43 dnsmasq[714]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Jan 1 00:00:43 dnsmasq[714]: asynchronous logging enabled, queue limit is 5 messages
Jan 1 00:00:43 dnsmasq-dhcp[714]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 1 00:00:43 dnsmasq[714]: read /etc/hosts - 5 addresses
Jan 1 00:00:43 dnsmasq[714]: using nameserver 183.81.133.151#53
Jan 1 00:00:43 dnsmasq[714]: using nameserver 183.81.133.150#53
Jan 1 00:00:43 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 00:00:43 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 00:00:44 WAN Connection: WAN was restored.
Jan 1 00:00:44 kernel: usb 1-1.2: USB disconnect, address 4
Jan 1 00:00:45 rc_service: asus_usb_interf 749:notify_rc reboot
Jan 1 00:00:45 stop_wan(): perform DHCP release
Jan 1 00:00:45 kernel: br0: port 1(vlan1) entering disabled state
Jan 1 00:00:45 dnsmasq[714]: read /etc/hosts - 5 addresses
Jan 1 00:00:45 dnsmasq[714]: using nameserver 183.81.133.151#53
Jan 1 00:00:45 dnsmasq[714]: using nameserver 183.81.133.150#53
Jan 1 00:00:45 pppd[647]: Hangup (SIGHUP)
Jan 1 00:00:45 pppd[647]: Connect time 0.2 minutes.
Jan 1 00:00:45 pppd[647]: Sent 372 bytes, received 0 bytes.
Jan 1 00:00:45 kernel: br0: port 1(vlan1) entering listening state
Jan 1 00:00:45 kernel: br0: port 1(vlan1) entering learning state
Jan 1 00:00:45 kernel: br0: topology change detected, propagating
Jan 1 00:00:45 kernel: br0: port 1(vlan1) entering forwarding state
Jan 1 00:00:45 pppd[647]: Terminating on signal 15
Jan 1 00:00:46 pppd[647]: Terminating on signal 15
Jan 1 00:00:46 nmbd[574]: [2011/01/01 00:00:46, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jan 1 00:00:46 nmbd[574]: Samba name server RT-AC66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Jan 1 00:00:48 stop_wan(): perform DHCP release
Jan 1 00:00:49 WAN Connection: Fail to connect with some issues.
Jan 1 00:00:49 stop_nat_rules: apply the redirect_rules!
Jan 1 00:00:49 dnsmasq[714]: exiting on receipt of SIGTERM
Jan 1 00:00:49 kernel: usbcore: deregistering interface driver asix
Jan 1 00:00:49 kernel: usbcore: deregistering interface driver net1080
Jan 1 00:00:49 kernel: usbcore: deregistering interface driver rndis_host
Jan 1 00:00:49 kernel: usbcore: deregistering interface driver zaurus
Jan 1 00:00:49 kernel: usbcore: deregistering interface driver cdc_ether
Jan 1 00:00:49 dnsmasq[781]: started, version 2.65 cachesize 1500
Jan 1 00:00:49 dnsmasq[781]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Jan 1 00:00:49 dnsmasq[781]: asynchronous logging enabled, queue limit is 5 messages
Jan 1 00:00:49 dnsmasq-dhcp[781]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 1 00:00:49 dnsmasq[781]: read /etc/hosts - 5 addresses
Jan 1 00:00:49 dnsmasq[781]: using nameserver 183.81.133.151#53
Jan 1 00:00:49 dnsmasq[781]: using nameserver 183.81.133.150#53
Jan 1 00:01:01 rc_service: wanduck 496:notify_rc restart_wan_if 1
Jan 1 00:01:01 rc_service: restart_wan_if 1 is waitting reboot...
Jan 1 00:01:11 rc_service: skip the event: restart_wan_if 1.
Jan 1 00:01:12 rc_service: wanduck 496:notify_rc restart_wan_if 0
Jan 1 00:01:12 rc_service: restart_wan_if 0 is waitting reboot...
Jan 1 00:01:22 rc_service: skip the event: restart_wan_if 0.
Jan 1 00:01:27 rc_service: wanduck 496:notify_rc restart_wan_if 0
Jan 1 00:01:27 rc_service: restart_wan_if 0 is waitting reboot...
Jan 1 00:01:38 rc_service: skip the event: restart_wan_if 0.
Jan 1 00:01:39 rc_service: wanduck 496:notify_rc restart_wan_if 1
Jan 1 00:01:39 rc_service: restart_wan_if 1 is waitting reboot...
Jan 1 00:01:49 rc_service: skip the event: restart_wan_if 1.
Jan 1 00:01:53 rc_service: wanduck 496:notify_rc restart_wan_if 1
Jan 1 00:01:53 rc_service: restart_wan_if 1 is waitting reboot...
Jan 1 00:02:03 rc_service: skip the event: restart_wan_if 1.
Jan 1 00:02:04 rc_service: wanduck 496:notify_rc restart_wan_if 0
Jan 1 00:02:04 rc_service: restart_wan_if 0 is waitting reboot...
Jan 1 00:02:15 rc_service: skip the event: restart_wan_if 0.
Jan 1 00:02:17 rc_service: wanduck 496:notify_rc restart_wan_if 0
Jan 1 00:02:17 rc_service: restart_wan_if 0 is waitting reboot...
etc ..
etc ..
etc ..
