read my first post, I updated DM issue, it comes after some (much) time ...
I have read your post carefully, after 36 hours, still there is no option to downloadmaster. Obviously the software error.
I just got an answer from ASUS:I could not remember the last hard reset of my RT-AC68U, gave it a shot today: revert to factory defaults and manual configured the router.
The Client List behavior has not changed and stays unstable.
It is anyway an odd advise, with the last step "Click the Restore button" you will not Reset the router, but it will ask you for a configuration backup file.I just got an answer from ASUS:
Hello Robert Vandiver,
Thank you for your response.
It is recommended that after a firmware upgrade that you reset the router. If you have not already done so I advise that you do the following:
1. Open a web browser, type 192.168.1.1 or router.asus.com in the address bar, and then press Enter.
2. Enter the administrator username and password and then click OK.
3. In the Advanced Settings menu on the left side, click Administration.
4. At the top of the page, click the Restore/Save/Upload Setting tab.
5. Click the Restore button.
If the above steps do not work I advise that you downgrade the firmware.
We do value your business, thank you for being a part of the ASUS family.
If you have any other questions, please feel free to contact us again for assistance.
Please make note of your case number for future reference: N181235764
Regards,
Sobreina B.
So I guess that they have no solution to the bad firmware. I replied to them stating that they should send me one that works! The older firmware has bugs too, that is why I upgraded to the new firmware. / 86U as the router and 2 68U's as nodes
In recent versions of ASUS firmware, those are the correct instructions to reset to defaults. You are thinking of the "Restore Setting/Upload" button.It is anyway an odd advise, with the last step "Click the Restore button" you will not Reset the router, but it will ask you for a configuration backup file.
Good old help-desk reply, the wrong answer picked from the list of standard answers.
RT-AC68U:
The client status overview does not show all connected WiFi clients. In the Asus APP, however, all clients are displayed.
Is that the only issue you've had with the RT-AC66U_B1 on this firmware? I haven't had time to upgrade yet so I'm still on the previous 3.0.0.4.384.32799 and the client list always an issue where it drops and repopulates. I have an issue with some clients where the internet drops for 10 secs then reconnects I'm hoping this update addresses it.I'm seeing the same thing on my AC-66U B1.
The web interface does not properly display and count attached devices, my Android App only shows WiFi attached devices. Seems odd that Ethernet clients don't show at all using the web or the app.
Can you see Ethernet attached devices?
So glad I sold my two AC3200, one N66U and one AC68U and went Google WiFi when reading these firmware threads.
RT-AC68U
firmware:3.0.0.4.384_45149
After the installation of the new software restored the factory settings. No icon to access the downloadmaster, not always can be applied to change the name of the client.
its the same, bit by bit.Ok. thank you. Is there a difference between this version and the one I can download directly from the router (3.0.0.4.384_45149-g467037b)?
Did you erase NVRAM after installing the 384 build? I have a 68U handling 30-40 clients that was last booted a week ago and it is using only 58% RAM and CPU rarely over 10%. I'm also using it as a file server for my nightly backups.They shouldn't have left the 380 codebase, i tried the new 384 fw (different build's) several times onto the last one but all of them created the same problems on my router.
Most of the time the issues are the same, starting fresh with already 50% ram being in use, and that builds up by the minute. I have nothing running or connected on the router just some port fw's.
After a few hours the RAM is hitting 80% and over and the UI becomes already slower loading.
Few hours later RAM usage is above 90% and both CPU cores are hitting 100% to 90% up and down. Then you can wait when all connections on the router die. And so happened with the latest FW also.
I'm back to Merlin's last 380.70 build: all smooth and working.
OK got it, didn't do that earlier.Did you erase NVRAM after installing the 384 build? I have a 68U handling 30-40 clients that was last booted a week ago and it is using only 58% RAM and CPU rarely over 10%. I'm also using it as a file server for my nightly backups.
There's several ways to erase NVRAM. It is basically a factory reset - you'll lose all your settings. So best to backup your current settings and capture text using the shell command "nvram show > /jffs/settings.txt" (save it in jffs so it will survive a reboot). To be safe, best to copy it off the router.OK got it, didn't do that earlier.
What is the procedure?
I am on 380.70 FW now
which order should i follow?
Welcome To SNBForums
