undertherain
I'm just buying 2 flat ethernet cables to extend them from wall box to the adjacent room where I will put the router.It's hard to suggest something when we don't know where exactly this AP is going to be located, how far this garden is and how large it is. As you said above, better get the RT-AC66U B1 router from Amazon, see if it works for you, send it back if it doesn't. Then we celebrate the success or go back to drawing board to explore other options. APs with 2 x LAN ports are available, but most require PoE (Power over Ethernet) and make things a bit more complicated (additional power supply + PoE injector adapter needed).
Ok, I take RT-AC66U B1 and do the necessary tests, so AP with 2 simple ethernets do not exist?
I take everything on Amazon that for Christmas the return deadline is until the end of January 2020...
