RT-AC88U alternative
You can download specs for digitus (german too) and lapp on this site, they are massive copper (Kupfer AWG 23/1).
https://asset.conrad.com/media10/ad...ble-cat-6a-sftp-4-x-2-x-020-mm-grey-100-m.pdf
https://asset.conrad.com/media10/ad...t-6a-uftp-4-x-2-x-025-mm-light-blue-100-m.pdf
TruComp is something like in-house brand of conrad with good quality: https://www.all-electronics.de/conrad-produktmarke-tru-components/
Ah excellent, so when reading an AWG number is it already meant that it is 100% copper and not CCA?
Kupfer=copper
AWG is only about structure and dimension
I'll come back to ask you a question: before buying the long and shielded cable for the job I told you I have to buy a 20 mt. of cat6 unshielded.
I looked at Conrad as you wrote to me but for example of the LogiLink brand only of cat6 there are various internal sections of cables:
- CPV0021 - 4x2x0.13 mm2 - 100 mt.
- CPV0033 - 4x2x0.205 mm2 - 100 mt.
- CPV0035 - 4x2x0.25 mm2 - 100 mt.
- CQ2100U - 4x2x0.25 mm2 - 100 mt.
What changes?
And what changes between the CPV0035 model and the CQ2100U model?
I would not want to take a cable of too large a section (I must be able to crimp it with normal unshielded RJ45, I must not put it in the wall).
I apologize for all these questions but I'm trying to make myself a culture ...;)
Have a look at item details, different width (cross section, diameter) of copper, flexibility, isolation material.
Last one might be more flexible and made of PVC.
Why do you want to use unshielded? Cant understand why you want to do it for only few € less.
I took 50 meters. cable Legrand BTICINO art. 032754 - cat6 U / UTP - LSZH to extend a cat 5e cable that was already present.
I will buy the shielded cable to carry the signal upstairs.
Monday 20/01 should come to bring me the optical fiber after months that I waited (1,000 / 300).
After that I will do serious tests ...
