RT-AC88U WiFi Routing Problems
Schlameel
The router does not connect wireless clients sometimes. Two clients are connected to the wireless network, but one will not be able to communicate with the other. I can ping both clients from a third client and I can ping both clients from the router itself. However, one of the clients will respond "No route to host".
I am using Pi-hole for DNS, if that matters.
Any suggestions would be appreciated.
Make sure your clients are properly set to DHCP and not to a static IP.
Most common issue there is mismatched network masks. Might be worth making sure you don't have a second rogue DHCP server on your network.
I disabled the DHCP server on the router and from both wireless and wired clients I ran:
# sudo nmap --script broadcast-dhcp-discover
and got no response. I enabled the DHCP server on the router and got a proper response.
I cannot find evidence of another DHCP server on my network, but thank you for the help.
