RT-AX86U Pro (merlin firmware: 388.1_0) as default aimesh & RT-AC68U as aimesh node
Hey, I have the same problem. Reset a few times with the LAN cable doesn't work.
The solution that works for me is to use the Internet port (blue one) on AC-68U, not the LAN ports (yellow port).
I can't find anywhere to mention this, hopefully can resolve your issue.
Thanks for all the tips, the important thing is that I managed to achieve my goal.
I know that Asus wrote a warning about this in the GUI, because thanks to this I was able to solve the problem.
However,
I will write again that I did not disable DHCP in the RT-AX86U PRO once during the Aimesh installation,
so I did not have the opportunity to read this message before!
The RT-AX86U PRO router was fully configured and I did not use DHCP in the router.
Only now I have enabled the dhcp server in the RT-AX86U PRO router in t
As for replacing RT-AC68U as Aimesh Node, I'm considering: RT-AX55 or RT-AX58U
However, I don't know if it's a good choice?
I would go with an RT-AX86S if I wanted a lower cost option for an AiMesh node.
