With which main router and other network components and Wi-Fi environment?
Unless you've done a full reset on the entire network, resetting a single device on it is not indicative of its worth.
I agree with this comment. Because there are so many parameters that need to be plugged in to make them the best they can be...
I really would like to know though if this newest firmware 3.0.0.4.386_44985 is stable and running well.
I cringe at the idea of upgrading my Home system because when i originally purchased these units a year ago, i was all kinds of UNSTABLE, and constantly dropping the 2.4ghz.
I worked extensively with ASUS over a two week process (mainly because i had to hurry and get it stable because i had another network i was planning on setting up and needed it to be perfect). I had a rep write a BETA firmware for me specifically and was given several parameters to make the units connection with each other stable. Besides an occasional need to reboot the unit (which has only happened about 5 times total in the past year), it has been solid, therefore my hesitation to touch anything!
Current firmware BETA on my AX92U system (custom built for me, but I'm sure they released it to others because it worked!): 9.0.0.4_384_9831
The AX92U runs as a node on my network using Router: GT-AX11000. This unit needed to match the same settings as well and had a similar update to the firmware yet, not a BETA (it uses: Current Version : 3.0.0.4.384_9566)
Why then would i want to upgrade? Because I max out on the 5G wifi at 460 Mbps... sure would like go get closer to my 1 gig bandwidth.
Anyway, I'll download, but not install yet, waiting for more response on the current firmware to see if i'll risk it. Especially since i have TWO other networks using these units now that could use an update but i want them to be stable.
