Hi all,
With increasing energy prices, I figured it'd be a good idea to check out the power usage of the Asus RT-BE88U router running firmware version 3.0.0.6.102.33921.
To get the numbers, I grabbed my Brennenstuhl PM 231 Power Meter and plugged it into a 220V/230 outlet. I tested the router in various connectivity scenarios to determine its power consumption under different conditions with the delivered 19v power supply.
First, I set up a baseline by turning off everything connected to the router and unplugging all the ports on the device itself.
Now, here are the power consumption results for you to calculate your annual energy costs based on your specific setup and number of connected Ethernet ports:
I can push my 1Gbit/s fiber connection to full download speed without stressing the RT-BE88U's CPU at all. The quad-core processor barely shows any load, it eats network packages like cookies! Adding only approx. 0.1 Watt under load.
I'm quite happy with the Asus RT-BE88U's power efficiency. I no longer need that GPON Media Bridge I used to connect to my old RT-AC68U. That router is officially retired now!
Device / Connectivity | Consumption |
RT-BE88U, Bare Metal | 7.4 Watt |
SFP GPON Port | 0.5 Watt |
10G Ethernet Port (at 2.5G Negotiated) | 0.6 Watt |
2.5G Ethernet Port | 0.6 Watt |
1G Ethernet Port | 0.3 Watt |
USB 3 Port | 0.8 Watt |
WiFi, 2.4 GHz | 1.7 Watt |
WiFi, 5 GHz | 1.7 Watt |
