RT-N66U .352 Beta firmware
Well what I do is, the 30/30/30 reset.
There is no need for the 30/30/30 thing on the your RT-N66U device!
You can reset nvram om the N66U via the WPS-button only, I have done it several times. :rolleyes:
Just power off the router, press and hold the WPS-button and power it on again, the power-LED will start to flash rapidly then you release the WPS-button.
The unit will reboot it self with the nvram reset to default.
Done! :eek:
With kind regards
Joe :cool:
Why would you try to load a fw meant for the rt-n66u on the ac66u or ac66r?
I'm confused.
That would be because in some cases, the firmware is designed to work across the N66/AC66 models, and I had been led to believe (though I didn't note it here) that someone else had done so successfully based on another thread elsewhere. As it didn't for me, I figured I'd note it to prevent someone else from trying the same thing.
That'd never be the case. The hardware is totally different between these two routers.
