RT-N66U Fw 3.0.0.3.151 : issue with the Traffic Monitor
T4xus
Fisrt, I apologize for my bad english.
I have a RT-N66U for few month which worked fine with fw 3.0.0.3.102... Yesterday I have updated the fw with the version 3.0.0.3.151 and I have found an issue with it.
The problem is with the Traffic Monitor : normally you can see data emission and reception both on LAN and WAN monitor. For example, if I download a file with my NAS or my computer (both wired the the router) I can see a data reception on the WAN monitor and a exactly same-shaped data emission on the Wired monitor. But, since I have done the update with fw 3.0.0.3.151 I can see the data reception on WAN monitor but not the data emission on the wired monitor (All worked fine with 3.0.0.3.102 fw).
Some pic to illustrate :
Have you found same issue with that fw?
Thank you.
I have re-flashed with the firmware 3.0.0.3.102 and the traffic monitor is working fine...
This is a real issue for the firmware 3.0.0.3.151, perhaps this is a scale problem (we can see very little lines on the "wired screen")...
