scMerlin scMerlin - service and script control menu for AsusWRT-Merlin
Apparently, yes.
Sep  4 05:21:17 RT-AC86U-4608 scmerlin: MD5 hash of scmerlin does not match - downloading updated v1.1.3
Sep  4 19:07:31 RT-AC86U-4608 scmerlin: MD5 hash of scmerlin does not match - downloading updated v1.1.3
Thanks, ever since the AC86U JFFS corruption debacle, I'm a bit paranoid of MD5 mismatches!
From "t. View router temperatures" menu i got incorrect symbol in temperature output:
CPU: 74▒C
2.4 GHz: 49.5°C
5 GHz: 54°C
Tried to change it in the script but did not help. Still got "▒" symbol (ASCII code 176 or 177) instead of degree symbol then i figured out where it comes from:
RT-AC68U:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 73▒C
Router is storing wrong symbol. I guess only ASUS or @RMerlin can fix it because this file is generated and updated by router itself.
What i did: reconfigured cut to only take digits after ":" (sorry i am not that fluent with cut) and add degree symbol (ASCII code 167).
To achieve this i changed line #558 in /jffs/scripts/scmerlin script from:
Bash:
printf "CPU:%s\\n" "$(cut -f2 -d':' /proc/dmu/temperature)"
To:
Bash:
printf "CPU: %s°C\\n" "$(cut -c19-20 /proc/dmu/temperature)"
but it's not perfect.
@Jack Yaz can you please take a look at that in your spare time?
Of course it is priority #999999 :) very insignificant.
Bash:
To:
Bash:
sorry for the delay. can you run the below and let me know if it achieves the same thing please?
printf "CPU:%s\\n" "$(cut -f2 -d':' /proc/dmu/temperature | awk '{$1=$1;print}' | sed 's/..$/°C/')"
printf "CPU:%s\\n" "$(cut -f2 -d':' /proc/dmu/temperature | awk '{$1=$1;print}' | 's/..$/°C/')"
missing "sed" command
@Jack Yaz yes it does:
CPU:73°C
just curious,
is it also possible to see (make/add) a addon all temperature from all aimesh nodes connected ?
just curious,
aimesh code is all closed source so I don't imagine there's a way to do this without setting up some sort of ssh solution to the IPs of the nodes
thx for explaining.
Just wanted to say thanks to all and Jack Yaz for this, my Asus rt-ac86u (latest merlin) router web ui sometimes vanishes for good, no rebooting or unplugging and waiting fixes it only a hard reset + full reinstall from scratch, but next time it happens I will give scmerlin a shot.
Attempting to run scmerlin on RT-AC68U and I'm getting the left frame all jumbled up. Not sure if this is due to new branch and merlin not being supported on this router anymore or not. Is there a way to fix this?
Try refreshing cache.
Yes, as mentionned by visortgw, normally this is fixed by clearing the browser cache (pressing Ctrl+F5 keys).
Thanks. Will give it a try.
