scMerlin scMerlin - service and script control menu for AsusWRT-Merlin
Hello Jack,
After installing 384_19 firmware on the RT-AC86U I can see the syntax error coming from the ScMerlin script and it refuses to run the code.
(Before update the router fw, ScMerlin was updated first to v1.1.2)
Do you know this issue?
could be jffs corruption, which is a known problem on the 86u. i'd recommend formatting and restoring a pre /.19 backup of jffs
Sorry for the delay. If you switch to the develop branch it should be OK to test!
scmerlin develop
Thank you, the script worked great! Now I don't ever need to log on to the WebUI for checking simple temperature readings!
v1.1.3 is now available
Changelog:
  • NEW: Add option to view temperature of CPU and wireless radios
  • CHANGED: Rename entware option from t to et
Thank you for this @Jack Yaz !
I am getting this on my AX88U:
Temperatures
CPU: 55°C
wl: wl driver adapter not found
2.4 GHz: °C
5 GHz: 38°C
Press enter to continue...
I will try a reboot to see if this helps.
Temperatures
CPU: 55°C
2.4 GHz: °C
5 GHz: 38°C
that didn’t help. Getting the same output.
Temperatures
CPU: 55°C
2.4 GHz: °C
5 GHz: 38°C
hm, AX88U must use a different interface for 2.4ghz other than eth5
I use these eth6 and eth7 to get the temps:
wl -i eth6 phy_tempsense
wl -i eth7 phy_tempsense
I replaced the “wl -i....” eth5 and eth6 commands in the script with eth6 (2.4 GHz) and eth7 (5GHz) and now they display just fine.
Temperatures
CPU: 55°C
2.4 GHz: 38°C
5 GHz: 40°C
hello.
i got this on my ac3100 router
Temperatures
awk: /sys/class/thermal/thermal_zone0/temp: No such file or directory
CPU: °C
2.4 GHz: °C
5 GHz: °C
hello.
Temperatures
CPU: °C
2.4 GHz: °C
5 GHz: °C
Try these to find your “eth” numbers for your router:
nvram get wl0_ifname
nvram get wl1_ifname
hello.
Temperatures
CPU: °C
2.4 GHz: °C
5 GHz: °C
for cpu, can you run the below and show me the output please?
cat /proc/dmu/temperature
Temperatures
CPU: 55°C
2.4 GHz: 38°C
5 GHz: 40°C
should be fixed in the hotfix i just pushed
I'm getting that same output on my AC88U
Anton
@Jack Yaz looks good here on an RT-AX88U. Thank you! :)
##               __  __              _  _          ##
##              |  \/  |            | |(_)         ##
##    ___   ___ | \  / |  ___  _ __ | | _  _ __    ##
##   / __| / __|| |\/| | / _ \| '__|| || || '_ \   ##
##   \__ \| (__ | |  | ||  __/| |   | || || | | |  ##
##   |___/ \___||_|  |_| \___||_|   |_||_||_| |_|  ##
##               v1.1.3 on RT-AX88U                ##
##       https://github.com/jackyaz/scMerlin       ##
Temperatures
CPU: 71°C
2.4 GHz: 50°C
5 GHz: 50°C
andresmorago@RT-AC3100-0548:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 81▒C
I'm getting this output on my AC88U
Temperatures
CPU: °C
2.4 GHz: °C
5 GHz: °C
Anton
Works great on both of my RT-AC86U routers. It is real handy for checking temps on the AiMesh node.
