scMerlin scMerlin - service and script control menu for AsusWRT-Merlin
@Jack Yaz works fine on AC86U [Main Router] - but fails on AC5300 [Aimesh Node] with this message ...
Temperatures
awk: /sys/class/thermal/thermal_zone0/temp: No such file or directory
CPU: °C
wl: wl driver adapter not found
2.4 GHz: °C
5 GHz: °C
For your info - on my AC5300 it is eth1 and eth2 for wl0_ifname and wl1_ifname respectively
and output of ... cat /proc/dmu/temperature ... is ... CPU temperature : 70▒C
Temperatures
CPU: °C
2.4 GHz: °C
5 GHz: °C
I'll push a further hotfix tonight for all other affected models. Hopefully that'll solve it
Thanks - it's "little" issues like this [variety of different eth?'s across router models] that makes us non-coders FULLY appreciate the efforts that RMerlin and the rest of you add-on specialists have to contend with when making things simple for the rest of us. The inconsistencies across the Asus model range must make coders' lives more than just "challenging" ... [including the tasks of the stock firmware coders!].
I for one fully support RMerlin's decision to take a breather until the 386 code settles - and hope that it reduces rather than amplifies the fiddly bits from one model to the next.
@kernol I found some time before I go out for the day and pushed some fixes, please update and let me know if all functional? I'm unsure on the CPU fix since I can't test it myself
Almost done - results below ...
Temperatures
CPU: °C
2.4 GHz: 49°C
5 GHz: 48°C
Temperatures
CPU: °C
2.4 GHz: 49°C
5 GHz: 48°C
Hm, that error shouldn't happen since I test if it exists:
if [ -f /sys/class/thermal/thermal_zone0/temp ]; then
wait a few minutes and check for another update? Github cache may not have caught the latest after I posted
Just ran option "uf" - and that has fixed it ... result now ...
Temperatures
CPU: CPU temperature    : 69▒C
2.4 GHz: 49°C
5 GHz: 48°C
MANY thanks
Temperatures
2.4 GHz: 49°C
5 GHz: 48°C
MANY thanks
Hm, the examples I was shown only had a single space after temperature. "cut" it is - give Github a few minutes to expire your cache and update again please
Fully sorted ...
Temperatures
CPU: 70▒C
2.4 GHz: 49°C
5 GHz: 48°C
EDIT: Just a strange character for the degree symbol for the CPU temp - not seen on AC86U.
It has been there from the start - following that cat command you required. Appears to be the symbol for Medium shade' with code point U+2592 ??
Works perfectly now on my AC88U. Thanks Jack Yaz!
Temperatures
CPU: 65▒C
2.4 GHz: 43°C
5 GHz: 50°C
fixed for me on my ac3100. i do get the strange character instead of the degree symbol
Choose an option:    t
##               __  __              _  _          ##
##              |  \/  |            | |(_)         ##
##    ___   ___ | \  / |  ___  _ __ | | _  _ __    ##
##   / __| / __|| |\/| | / _ \| '__|| || || '_ \   ##
##   \__ \| (__ | |  | ||  __/| |   | || || | | |  ##
##   |___/ \___||_|  |_| \___||_|   |_||_||_| |_|  ##
##               v1.1.3 on RT-AC3100               ##
##       https://github.com/jackyaz/scMerlin       ##
Temperatures
CPU: 80▒C
2.4 GHz: 49°C
5 GHz: 53.5°C
Press enter to continue...
Tested latest on 87u (update forced)
Temperatures
CPU: 70�C
2.4 GHz: 45.5°C
5 GHz: °C
Im not seeing my 5G come up either. Also on the 87R(U)
When I run
wl dump
Im not seeing anything listed for my 5G band
Im seeing eth1 for the 2.4GHz ifname value and wifi0 for the 5GHz ifname value
edit: So im looking around in the quantenna system now to see if there is an easy way to get at the 5 GHz info for the 87
This should get you the 5GHz temp on the 87s "temperature_rfic_internal" should be the value you want.
qcsapi_sockrpc get_temperature
Temp working correct now on 87u with this update :)
Temperatures
CPU: 71�C
2.4 GHz: 45.5°C
5 GHz: 54.1°C
Thanks @Jack Yaz & @Swinson
Was there a "min update" to scmerlin published between yesterday and today? Just want to make sure it's legit and my JFFS isn't going corrupt ;)
Was another update pushed to scmerlin between today (@ my post above, 10:57 AM EST timezone) and right now?
Apparently, yes.
Sep  4 05:21:17 RT-AC86U-4608 scmerlin: MD5 hash of scmerlin does not match - downloading updated v1.1.3
Sep  4 19:07:31 RT-AC86U-4608 scmerlin: MD5 hash of scmerlin does not match - downloading updated v1.1.3
